Want to add new scripting functions for your jython scripts to use? Know some Java (or aren’t afraid of learning new things)? This might be for you.
I’ve written a blog post on how easy it is to add new scripting functions to Ignition.
http://ignitionprogramming.blogspot.com/2011/07/adding-scripting-functions.html
You’ll need the Ignition SDK to make this work (available at the inductiveautomation.com downloads page).
If you want a quick way to get going after installing the SDK, you can also grab the playground project I created, which has all the build files and configuration already in place. http://ignitionprogramming.blogspot.com/2011/06/ignition-playground-project.html
