Hi
i have one project and try to lunch it from my mobile. it gave me this massage
java.io.EOFException
i don’t know what is the problem. FYI .it lunch from PC without any problem. my phone working under android v 3.5
thanks
Tamer
What version of Ignition are you using (very important for us to know )?
Also, check to see if accepting cookies is enabled.
[quote=“Greg.Simpson”]What version of Ignition are you using (very important for us to know )?
Also, check to see if accepting cookies is enabled.[/quote]
Thanks Greg for your fast replay.
I am using v7.5 and accepting cookies is enabled.
thanks
Tamer
Can you try another device like an iPhone?
I just checked internally, we did have an issue with the mobile module in version 7.5. I am showing that it has been fixed for version 7.5.1. You can download the latest beta release from our website, that would be 7.5.1-beta4.
I am also experiencing the same issue. I know prior to 7.5 mobile was working fine.
We use Blackberry and iPhones for all of our users and all get the same error as described.
We applied 7.5.1 beta5 today and still get the same issue. java.io.EOFException.
Any other suggestions to try?
The devices have “Accept Cookies” turned on as well as “run java script” as on.
I have found the source of the issue to be Java 7 that was loaded onto our Ignition server. If I run Java 6 and 7 on the server the error persists but works fine once Java7 is unloaded.
At this point my mobile devices are working as normal.
That was going to be my first question, what version of Java are you using?
The mobile module is only working with Java 6
