It is currently Sun May 19, 2013 1:55 am
Post new topic Reply to topic  [ 8 posts ]
 Mobile Client Error Message
Author Message
Corporal
Corporal
Post Mobile Client Error Message
I'm receiving this message when launching the moblie client.
java.lang.IllegalStateException: Client VM not initialized.
Any suggestions?
Thanks.
Wed Jun 27, 2012 10:57 am
Profile
Moderator
Moderator
Post Re: Mobile Client Error Message
That means that the mobile module doesn't know where java.exe is located on the server. Go into the Ignition Gateway configuration page and select Mobile > Settings on the left hand side. Enter in the path to Java in the Java Path text field. It is usually something like:
Code:
c:\program files\java\jre6\bin\java.exe
Save and try launching again.
_________________
Travis Cox
Inductive Automation
Technical Support Rep.
Wed Jun 27, 2012 11:01 am
Profile WWW
Corporal
Corporal
I've made those changes and now I'm seeing this message.
com.inductiveautomation.mobile.gateway.InvalidSetupException: Java setup is not valid for launching mobile VMs.
We're running CentOS and here's our path
/usr/bin/java
Wed Jun 27, 2012 11:22 am
Profile
Moderator
Moderator
/usr/bin/java
Are you running Sun/Oracle Java or OpenJDK? Headless or do you have a desktop environment installed? We'll help you troubleshoot over the forums, but you should be aware that the mobile module is not officially supported on Linux.
_________________
Kevin Herron
Software Developer
Wed Jun 27, 2012 11:56 am
Profile WWW
Corporal
Corporal
Kevin:
We are running Sun/Oracle Java and headless CentOS Linux on a virtual machine with 1 GB of memory.
Is there a worksheet for memory usage required by Ignition clients? I know the default is 256MB. Is it possible to reduce or increase this size?
Wed Jun 27, 2012 12:19 pm
Profile
Moderator
Moderator
Mobile module doesn't work at all on a headless linux install because of the technology used to run the client VMs. You'll need a graphical environment (X) installed. You'll also certainly run into memory problems with just 1GB for the VM, almost immediately, because the way the mobile module works is that for each mobile session connected a VM is running the client on the gateway.
_________________
Kevin Herron
Software Developer
Wed Jun 27, 2012 12:29 pm
Profile WWW
Cadet
Cadet
I am experiencing a similar issue. I'm running Ignition 7.42 (need to upgrade to 7.5 still) on a VM with Ubuntu 9.04. I assume this is considered a headless installation as it is accessible only via SSH. Based on the responses I've read here, am I to understand then that if I install KDE or X or something of the like then the mobile module would work?
Regards
Mon Jul 16, 2012 1:34 am
Profile
General
General
Indeed. You'll need x installed. The mobile module on Linux actually creates a virtual x session and that's what you're looking at.
Mon Jul 16, 2012 5:57 am
Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 3 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
