It is currently Thu May 23, 2013 5:30 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 23 posts ]  Go to page 1, 2  Next
 Default is not default
Author Message
General
General
Post Default is not default
I just upgraded my gateway from 7.2.9 to 7.4.3
A number of projects were using the Default authentication profile. After the upgrade, they all got a error about the a missing default profile.
I had to change the Default profile to default. Then I had to change all the projects that used the Default profile to use the default profile. :(
Thu Jun 07, 2012 3:08 pm
Profile WWW
Moderator
Moderator
Post Re: Default is not default
This sounds very odd. Why did you "have" to change the capital "D" to a lowercase "d"? Do you have a 7.2 backup sitting around that you could try and replicate this on to see if it happens again?
_________________
Carl Gould
Software Development
Inductive Automation
Fri Jun 08, 2012 7:23 am
Profile WWW
General
General
I have the auto backup. I think it was just before the update.
Can I get a ticket number to upload it to? (it's 20M)
Fri Jun 08, 2012 11:24 am
Profile WWW
Moderator
Moderator
Ticket number is 7239
_________________
Greg Simpson
Technical Support Rep
Fri Jun 08, 2012 12:37 pm
Profile
General
General
Ticket number is invalid or ....
I think I waiting to long. Can we try a different/renewed one?
Mon Jun 11, 2012 11:19 am
Profile WWW
Moderator
Moderator
I just reactivated that ticket, you should be able to attach to it now. Again, that is ticket 7239.
_________________
Greg Simpson
Mon Jun 11, 2012 1:16 pm
Profile
General
General
My file has been successfully uploaded
Mon Jun 11, 2012 1:40 pm
Profile WWW
Moderator
Moderator
Thanks!
_________________
Greg Simpson
Mon Jun 11, 2012 2:21 pm
Profile
Moderator
Moderator
Well, I'm looking at your Gateway but I'm not sure what I should be looking at.
You have an authentication profile called "default". Some of your projects are referencing "default" - these are fine. Some are referencing "Default": these are broken. Perhaps authentication profile lookup was case insensitive in 7.2, and you'd typed them in inconsistently...
_________________
Carl Gould
Wed Jun 13, 2012 3:39 pm
Profile WWW
General
General
Wrong backup then. That was after I changed everything from "Default"
I really should take a backup *before* I mess with things.
Like I said, everything was "Default" then I upgraded and everything looked good until you tried to open a project. Then you would get an error about being unable to find the "default" profile even though the project referenced the "Default" profile which did exist.
is "default" hard coded somewhere?
Thu Jun 14, 2012 12:34 pm
Profile WWW
Moderator
Moderator
Its not hard coded but there is a "default" profile when Ignition is installed
_________________
Greg Simpson
Thu Jun 14, 2012 2:19 pm
Profile
General
General
Just tried to recreate this on my dev box.
Upgrading from 7.4 to 7.5 and it all worked fine. Everything was "default". I changed it to "Default" and then upgraded.
Thu Jun 14, 2012 2:59 pm
Profile WWW
General
General
Problem is back on our Demo system.
I have a backup I can upload.
Tue Jul 03, 2012 12:25 pm
Profile WWW
Moderator
Moderator
Upload it to the same tag number, 7239
_________________
Greg Simpson
Tue Jul 03, 2012 2:37 pm
Profile
General
General
Uploaded.
System is running 7.4.3(b995)
I also upload the login details in a separate file.
Wed Jul 04, 2012 7:35 am
Profile WWW
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
