from the log file:
java, -cp, "/usr/local/bin/ignition/contexts/main/core/launch/launchclient.jar:/usr/local/bin/ignition/contexts/main/mobile_wdir/mobile-common.jar:/usr/local/bin/ignition/contexts/main/mobile_wdir/mobile-client-bootstrap.jar", -Dmobile.callback.interface=localhost, -Dmobile.callback.port=45900, -Xmx256M, com.inductiveautomation.mobile.MobileMain
When run on the command line:
No command 'java,' found, did you mean:
Command 'javac' from package 'openjdk-6-jdk' (main)
Command 'javac' from package 'gcj-4.3' (universe)
Command 'javac' from package 'gcj-4.4-jdk' (main)
Command 'javac' from package 'ecj' (main)
Command 'javap' from package 'openjdk-6-jdk' (main)
Command 'java' from package 'gcj-4.4-jre-headless' (main)
Command 'java' from package 'openjdk-6-jre-headless' (main)
Command 'java' from package 'gij-4.3' (universe)
Command 'java' from package 'jamvm' (universe)
Command 'java' from package 'cacao' (universe)
Command 'javah' from package 'openjdk-6-jdk' (main)
Command 'javah' from package 'gcj-4.3' (universe)
Command 'javah' from package 'gcj-4.4-jdk' (main)
java,: command not found
robert@wiskers:/mnt/home/home/robert$ which java
/usr/bin/java
When run again without the ','s:
java.lang.NullPointerException
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:186)
at gnu.awt.virtual.VirtualToolkit.setDefaultToolkit(VirtualToolkit.java:388)
at gnu.awt.virtual.VirtualToolkit.initDefaultToolkit(VirtualToolkit.java:86)
at com.inductiveautomation.mobile.MobileMain.main(MobileMain.java:58)
Exception in thread "main" java.lang.StackOverflowError
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:287)
at java.lang.ClassLoader.loadClass(ClassLoader.java:266)
at sun.reflect.GeneratedConstructorAccessor1.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:532)
at java.lang.Class.newInstance0(Class.java:372)
at java.lang.Class.newInstance(Class.java:325)
at gnu.awt.virtual.VirtualToolkit.setDefaultToolkit(VirtualToolkit.java:389)
at gnu.awt.virtual.VirtualToolkit.<init>(VirtualToolkit.java:98)
at gnu.awt.virtual.VirtualToolkit.<init>(VirtualToolkit.java:107)
at gnu.awt.virtual.VirtualToolkit.<init>(VirtualToolkit.java:112)
at gnu.awt.virtual.VirtualToolkit.<init>(VirtualToolkit.java:116)
(snip)
Had to remove a bunch of messages. They looked like the last ones. I can only post 60000 characters, I need 74935
Somebody practicing recursion?
And just for the fun of it:
java -version
java version "1.6.0_20"
OpenJDK Runtime Environment (IcedTea6 1.9.4) (6b20-1.9.4-0ubuntu1~10.04.1)
OpenJDK Server VM (build 19.0-b09, mixed mode)
