I recently upgraded the Ignition to 7.6.2-rc3 on Ubuntu. After the upgrade from 7.6.1 to 7.6.2-rc3 the gateway doesn’t start at all. I reset the Hardware and even rolled back installation to previous stable release but it doesn’t start at all. Please Help.
We just hit this during our internal testing. Here is a workaround that works for us:
Navigate to your Ignition install folder (most likely under /usr/local/bin/ignition) and then navigate to the /lib folder. Within the /lib folder, create a temp folder (note that you must have sudo access):
sudo mkdir temp
Then make that folder accessible to the user running Ignition:
sudo chown yourusername temp
After this, your Gateway should be able to start. We are implementing a fix to take care of this issue, which will be part of the next 7.6 RC.
