| Author |
Message |
DarioC
Cadet
 Multi language support
We have customer all around the world, for us an easy multi language support is an essential feature. We are valuating to ditch our current HMI software and switch to Ignition but we need an easy way to handle multiple languages.
One possible solution will be make a tool that browse the project and extract all the strings in a table. The table may have a column that help identify the source of the string (Example: page.object.property) and one column for each project defined language. Then, at run time, the tool will replace the string based on the selected language.
| Mon Aug 06, 2012 2:28 pm |
Travis.Cox
Moderator
Joined: Sun Apr 02, 2006 2:46 pm Posts: 1974 Location: Sacramento, CA
 Re: Multi language support
There is a way to do this yourself in Ignition. You can make a client dataset tag that holds all of the translations for each language. Each component that has text can be bound to an expression pulling out the selected language from one of the rows in the dataset.
_________________ Travis Cox
Inductive Automation
Technical Support Rep.
| Wed Aug 08, 2012 7:47 am |
Pilotek
Private
Good morning/afternoon. It means that Ignition doesn't have any built-in (pre-prepared) tool for switching languages on Vision client machines?
And if there is some language-switching tool included - are there also (frequently used) System strings (not only Project object's texts) included for the possibility of translation? E.g. Viewer Menu, various pop-up Notices/Warnings/Errors etc. which may occur on operator (Viewer) screen.
| Thu Nov 22, 2012 6:14 am |
Travis.Cox
Moderator
There is nothing built-in right now. We plan on building in a translation tool for the clients soon.
| Mon Nov 26, 2012 9:03 am |
Pilotek
Private
It would be nice if all the system texts that are ever displayed on View client screens could be exported to some CSV file, there translated by system integrator and imported back to enable switching between the View client languages.
Is there some estimated time of releasing the translation tool?
| Tue Dec 11, 2012 12:13 pm |
Travis.Cox
Moderator
We don't have an exact time for when it will be released but it is looking like around June 2013. The idea is that we can push all text through a translation map automatically. You can translate any of the strings to multiple languages and Ignition will automatically switch it based on the language.
| Wed Dec 12, 2012 8:15 am |
pdibenedetto
Private
Joined: Wed Oct 05, 2011 12:10 pm Posts: 31 Location: Rosario, Argentina
+1
| Wed Dec 12, 2012 3:12 pm |
zxcslo
Sergeant
Joined: Fri Oct 14, 2011 6:54 am Posts: 49 Location: Slovenia, Europe
++1 We really need that.
| Sat Jan 19, 2013 5:22 am |
Manu.Pernu
Cadet
+1
| Mon Mar 25, 2013 10:22 am |
billmorone
Trooper
I was wondering how it was going with the multi-language support feature -- is it still being worked on? If so, what will it look like and when is the scheduled release date? Thanks!
| Fri Apr 05, 2013 1:00 pm |
dymytr
Trooper
Yes! It's good idea!
| Thu Apr 11, 2013 7:01 pm |
Colby.Clegg
Moderator
Travis' answer above is still accurate, this feature is one of the primary features of 7.7. It might not be done by June, since 7.6 is only being released on May 7th, but we're going to try to keep the cycle as short as possible.
Regards,
_________________ Colby Clegg
Software Development
| Wed Apr 17, 2013 3:37 pm |
