It is currently Wed May 22, 2013 6:25 pm
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2, 3  Next
 pdf orientation
Author Message
General
General
Post pdf orientation
In both landscape and portrait orientations of pdfs, The viewer will only give me a portrait view.
How can I get a wideview?
Tue Jul 24, 2012 5:07 am
Profile
Moderator
Moderator
Post Re: pdf orientation
What are you using to view the pdf?
Using the PDF Viewer, I have imported landscaped documents and they display as landscaped.
_________________
Greg Simpson
Inductive Automation
Technical Support Rep
Tue Jul 24, 2012 8:45 am
Profile
General
General
I've tried the pdfill editor and also tried to modify the pdf plot from autocad.
I can't get this to work. I have the pdfs and the pfls I have tried if someone wants to take a look.
Fri Jul 27, 2012 4:11 am
Profile
Moderator
Moderator
If you want to upload them or email them to support@inductiveautomation.com you can.
Keep in mind
Quote:
In practice, it is able to view many PDFs, but it does have trouble with some, especially PDFs created by AutoCAD.
http://inductiveautomation.com/support/ ... viewer.htm
_________________
Greg Simpson
Fri Jul 27, 2012 7:50 am
Profile
General
General
Greg, are we talking about pdfs published from within AutoCAD, or plotted through Adobe or PDFCreator or whatever can be used as a printer/plotter?
_________________
Jordan
Duct tape is like The Force. It has a light side, a dark side, and it holds the universe together.
Fri Jul 27, 2012 9:18 am
Profile
Moderator
Moderator
The quote I used is from the users manual where it says the PDF viewer has trouble displaying PDFs made with AutoCAD.
_________________
Greg Simpson
Fri Jul 27, 2012 9:49 am
Profile
Moderator
Moderator
The only way that you're going to be able to display your pdf in a landscape format is by using the ActiveX Adobe PDF Viewer. One setback going this route is it will require you to use 32 bit Ignition and 32 bit Java. I have confirmed that your pdf does display properly, in a landscape format, using this component.
_________________
Greg Simpson
Fri Jul 27, 2012 1:58 pm
Profile
General
General
Greg.Simpson wrote:
The only way that your going to be able to display your pdf in a landscape format is by using the ActiveX Adobe PDF Viewer. One setback going this route is it will require you to use 32 bit Ignition and 32 bit Java. I have confirmed that your pdf does display properly, in a landscape format, using this component.
If I have a 64bit installation on my server and am launching clients from 32 bit machines, is this the same or do I need a 32bit installation to enable this feature?
Are there plans for this feature to be available in a future Ignition release for 64x?
Wed Aug 01, 2012 5:08 am
Profile
Moderator
Moderator
It should run fine on the 32 bit clients. The Adobe AcriveX control is just buggy on the 64 bit systems. We ran a test on it this morning and found that you can add the component to the project on a 64 bit machine, however, you probably wont see the file in the designer or the client. If you run a 32 bit client you should see it. I do not have a date as to when this will be fixed. Keep in mind the information from the users manual also:
Quote:
ActiveX Module
There is a free module available for separate download from our website that adds an ActiveX palette to the Vision module. This lets you use ActiveX controls in your windows. This module comes with some caveats, however. ActiveX doesn't play all that gracefully with Ignition, because it is written in Java. ActiveX controls will only work on Windows. They also draw themselves "on top of" the entire Vision client application. This means that nothing can overlap them, not even other windows or dropdown menus. Because of these technical limitations, this module is provided as-is, with limited technical support. These details aside, the ActiveX component can be a great way to integrate a full-fledged PDF viewer or web-browser into your Ignition Vision application.
_________________
Greg Simpson
Wed Aug 01, 2012 7:30 am
Profile
General
General
How about lauching adobe from ignition so I can view my Cad drawings in 64 bit Ignition as a temporary fix ...Possible?
Mon Aug 13, 2012 8:41 am
Profile
Moderator
Moderator
You can use the system.util.execute() function to execute commands via the operating system, including launching outside applications. You'll just have to get the syntax right, which can be tricky sometimes. Check out the user manual for a simple example: http://inductiveautomation.com/support/ ... xecute.htm
_________________
Dave Fogle
Technical Support
Mon Aug 13, 2012 9:34 am
Profile
General
General
I installed 32bit Ignition and tried to view my landscaped pdf. No success, Can I send my pdf to you and we can see if you can get it to work?
Tue Aug 21, 2012 8:59 am
Profile
Moderator
Moderator
Can you see it in the client/runtime?
_________________
Greg Simpson
Tue Aug 21, 2012 9:09 am
Profile
General
General
it is portrait view in the designer and in the client view.
Tue Aug 21, 2012 9:10 am
Profile
Moderator
Moderator
either email it to support@inductiveautomation.com or attach it to this thread
_________________
Greg Simpson
Tue Aug 21, 2012 9:13 am
Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: Google [Bot] and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
