It is currently Tue May 21, 2013 9:50 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
 Raspberry Pi
Author Message
General
General
Post Raspberry Pi
Well i was wandering how many of you out here have got your Rpi and what you think of it.
Is anyone else disappointed? Has any got a client running? what image did you use?
I was hoping the fedora remix or the debian would have a shot? any updates? I received mine and have got
the fedora remix running. no Ignition client yet .. Is it even possible since its an arm V6? I had thought that at least
a vision client would run. wont be a very intense one, maybe digital signage....
Mon Jul 09, 2012 5:51 pm
Profile WWW
General
General
Post Re: Raspberry Pi
Still waiting for mine, but my primary thought was for digital signage, like a production/pace counter thing. 1-3 screens that cycle. Non-critical stuff.
_________________
Jordan
Duct tape is like The Force. It has a light side, a dark side, and it holds the universe together.
Tue Jul 10, 2012 9:51 am
Profile
General
General
update...
I tried the fedora remix, QtonPi, and the debian squeeze.
I have yet to try the 'wheezy' but at the moment
I went back to debian squeeze package.
did an apt get update
was able to apt get openjdk 6
for whatever reason the 7 repository didnt work....
also got chromium browser.
I havent tried to get ignition itself on there, but i dont think the pi could handle it
anyway or is likely not compatible but it should......run a client...
from terminal I can ping my machine running ignition service.
it is running......but to no avail I have yet to 'see' the gateway homepage.
also i came across a really neat publication that documents the gpio and python.
its....www.themagpi.com
none the less I am not a linux pro and this is starting to feel like futile effort.
I was hoping to hear some success stories...
Tue Jul 10, 2012 6:56 pm
Profile WWW
General
General
Oracle JRE7 and JRE6 only supports headful java on an ARMv7 architecture. The Raspberry Pi is an ARMv6 system, so only headless java is supported.
THe system is not a power house, but once the system boots and is running, it is capable of being used as a intermediate OPC UA server. Ill post back with more soon, just trying to find time to do up a write-up of how to install Ignition on a RPi. I had this working an hour after I got mine....
Wed Jul 11, 2012 12:44 am
Profile WWW
General
General
sounds promising would love to learn from your write up.
Wed Jul 11, 2012 7:18 am
Profile WWW
General
General
whilst awaiting the write up, just some quick questions.
which distro image did you use?
How did you get network browse working?
I tried 'samba' but I still could not connect to my gateway.
I did not install ignition, I just want to launch clients.
Thu Jul 12, 2012 5:44 pm
Profile WWW
General
General
Has anyone else out here got the Pi running a client?
Sat Aug 04, 2012 1:27 pm
Profile WWW
General
General
Greetings all,
Well I have been trying to get Ignition on the RPi with no success while awaiting Kyles write up.
Below are the results of the commands added to the apt resources file.
sudo apt-get update yields the following results:::::
W: Failed to fetch http://archive.inductiveautomation.com/ ... on/Release Unable to find expected entry non-free/binary-armel/Packages in Meta-index file (malformed Release file?)
W: Failed to fetch http://archive.inductiveautomation.com/ ... ta/Release Unable to find expected entry non-free/binary-armel/Packages in Meta-index file (malformed Release file?)
E: Some index files failed to download, they have been ignored, or old ones used instead.
pi@raspberrypi:~$
My question would be..What are the correct repository links if there are any?
A quick thought would be is this even possible since it keeps 'expecting' armel packages?
My real intentions were to use this as just a client. I did 'appear' to get java installed.
Since it gave mention of being 'headless' does this mean it will not work as a client?
When I type '192.168.1.100:8088' in my browser which is the machine serving Ignition on my windows network
It fails to connect every time.......
Is there anyone else out there trying this thing?
I found a different unit that by far out muscles the RPi; its called the 'cotton candy'.
It looks allot more promising than the gooseberry......
Still anxiously awaiting Kyle Chase's 'write-up'..
Sun Aug 05, 2012 6:14 pm
Profile WWW
General
General
You cant use the repositories to install ignition on the RPi, you have to install manually from tar.gz. I recommend untarring them to /opt/ignition.
As for my write up, I've been absolutely swamped lately, so I have not had time. I am still going to get it done this month.
As previously stated, the RPi has an ARMv6 architecture, so it cant run headful using the Oracle binaries (so no client, only server). I have not tried openjdk, but I presume they would be the same. To get headful java from Oracle, you need an ARMv7 architecture. I have a few of the following boards on order.
http://www.hardkernel.com/renewal_2011/products/prdt_info.php?g_code=G133999328931
Im hoping to get debian/ubuntu running on them, as those operating systems support ARMv7 architectures.
Sun Aug 05, 2012 10:27 pm
Profile WWW
General
General
@Kyle,
Response appreciated! :prayer:
Please don't rush the write up on my account.
I am going to switch gears with the Pi and just use it to play around with
Python and other hardware via the GPIO.
It appears fruitless that it will run a graphical client, which is fine. It can have other uses.
The client was what I was wanting to use it for (digital signage). It can do many other things
that I will take advantage of.
Thank you again for the response!
Mon Aug 06, 2012 5:17 am
Profile WWW
General
General
Latest news:
https://blogs.oracle.com/henrik/entry/o ... _for_linux
Dennis
Wed Aug 15, 2012 11:45 am
Profile
General
General
sounds like something useful lies ahead for the gooseberry!! :thumb_left:
Wed Aug 15, 2012 4:33 pm
Profile WWW
General
General
From the release notes...
JDK for Linux on ARM
This release includes support for a new platform, JDK for Linux on ARM. The product offers headful support for ARMv6 and ARMv7.
No support is available for WebStart, Plug-In, Java Flight Recorder, and Garbage First (G1) Collector. Also some features of the Serviceability Agent are not available for Linux on ARM platform.
______________________________________________________________________________
So, I'm guessing that lack of WebStart support may be an issue?
_________________
Jordan
Thu Aug 16, 2012 1:48 am
Profile
Moderator
Moderator
It means no launching off the gateway on that machine, but you can launch from a shell script or shortcut still.
_________________
Kevin Herron
Software Developer
Inductive Automation
Thu Aug 16, 2012 4:29 am
Profile WWW
General
General
Good 'nuff!
_________________
Jordan
Thu Aug 16, 2012 6:39 am
Profile
Who is online
Search for:
Jump to:
