FactorySQL Front End On Remote Computer
| Author |
Message |
WildeKurt
Lieutenant
Joined: Tue Dec 04, 2007 8:47 am Posts: 66 Location: Southeast Iowa
For support purposes, is it possible to have multiple PC's with the FactorySQL front end installed to support one instance of the FactorySQL service which would be running in our data center. If so, would we need to purchase multiple licenses? Nearly all our support would be from remote locations.
| Tue Dec 04, 2007 8:51 am |
Carl.Gould
Moderator
Joined: Sun Apr 02, 2006 2:46 pm Posts: 3737 Location: Sacramento, CA
Sure, you can use a FactorySQL front-end to connect to a remote service. Only the FactorySQL service installaction in your data center needs to be licensed.
Hope this helps,
_________________ Carl Gould
Software Development
Inductive Automation
| Tue Dec 04, 2007 9:04 am |
WildeKurt
Lieutenant
 Transfering Licenses
Is it easy or even possible to transfer a license. I could think of occasions when running an instance of FactorySQL temporarily on site would be useful.
| Tue Dec 04, 2007 2:51 pm |
Carl.Gould
Moderator
Yes, you can unactivate an activated FactorySQL. You need an internet connection to do this instantly, or you can do it over the phone. Or you can buy a hardware USB dongle for easier floating licenses.
Up to you!
| Tue Dec 04, 2007 4:23 pm |
clark
Trooper
Joined: Tue Apr 04, 2006 12:15 pm Posts: 24 Location: Charleston, SC
How much is a hardware USB dongle? Can I transfer an existing license to it?
| Wed Dec 05, 2007 1:46 am |
Carl.Gould
Moderator
I'm going to defer on answering this for now. The USB dongles haven't been officially announced yet - see upcoming FactoryPMI 3.1 and FactorySQL 4.1 press release
| Wed Dec 05, 2007 9:00 am |
ilanlchait
Cadet
 Re: FactorySQL Front End On Remote Computer
Does the same go for FactoryPMI? i.e. can the license be transferred from one machine to another? Are the licenses transferrable from Linux <-> Microsoft? We want to start with FActoryPMI on a Windows machine initially with the goal of having it on our production Linux box.
| Wed Aug 19, 2009 11:10 am |
Colby.Clegg
Moderator
Yes, definitely. You can un-activate/activate as much as you want across Windows or Linux.
I think that currently the hardware activation keys don't work on linux, but that should be fixed with the next major release. Keep in mind, though, that hardware keys aren't required- the normal activation system is software only.
Regards,
_________________ Colby Clegg
| Wed Aug 19, 2009 12:15 pm |
