Any further developments on this?
I need to do the same thing - want to generate a default filename for saving a report, based on what was selected using the Row Selector.
I’m only filtering on one item so it’s a simple setup.
I know I could look at the Data Out and pick out the relevant column to get the filtered value, however this wouldn’t work if All Data was selected.
(I thought about comparing Data In to Data Out to see if they were/weren’t equal but looks like Data In isn’t available as a property)
Ignition version 7.6.6
Thanks.
