Greetings all,
Well I have been trying to get Ignition on the RPi with no success while awaiting Kyles write up.
Below are the results of the commands added to the apt resources file.
sudo apt-get update yields the following results:::::
W: Failed to fetch archive.inductiveautomation.com/ … on/Release Unable to find expected entry non-free/binary-armel/Packages in Meta-index file (malformed Release file?)
W: Failed to fetch archive.inductiveautomation.com/ … ta/Release Unable to find expected entry non-free/binary-armel/Packages in Meta-index file (malformed Release file?)
E: Some index files failed to download, they have been ignored, or old ones used instead.
pi@raspberrypi:~$
My question would be…What are the correct repository links if there are any?
A quick thought would be is this even possible since it keeps ‘expecting’ armel packages?
My real intentions were to use this as just a client. I did ‘appear’ to get java installed.
Since it gave mention of being ‘headless’ does this mean it will not work as a client?
When I type ‘192.168.1.100:8088’ in my browser which is the machine serving Ignition on my windows network
It fails to connect every time…
Is there anyone else out there trying this thing?
I found a different unit that by far out muscles the RPi; its called the ‘cotton candy’.
It looks allot more promising than the gooseberry…
Still anxiously awaiting Kyle Chase’s ‘write-up’…
