It is currently Wed Jun 19, 2013 4:59 pm
Post new topic Reply to topic  [ 4 posts ]
 Using for loop to move a container
Author Message
Trooper
Trooper
Post Using for loop to move a container
I have been having issues using a timer to move a container up and down not by just appearing at its new location but moving into place at a certain rate during the mouseEntered event so I went with a for loop as shown:
import time
y = 297
for y in range(107,197):
system.gui.moveComponent(event.source, 196, y)
y = y - 1
time.sleep(1)
if y == 107:
break
This doesn't work for me either even though it seems like it should, what it does is pause a second before moving the container to the final position of (196,107). Do you know why that is? Do you have a better method of doing this?
Fri Aug 03, 2012 10:02 am
Profile
General
General
Post Re: Using for loop to move a container
Your range starts at 107, so the second iteration y is 108 and the conditional for breaking the loop is met.
Seems like you'd be able to simplify that a bit too...
Code:
import time
y = 297 # why is this declared up here? is this used elsewhere?
x = 196
# get your range and reverse it
range_of_movement = range(107,197)
range_of_movement.reverse()
# move through each value in the range
for y in range_of_movement:
   system.gui.moveComponent(event.source, x, y)
   time.sleep(1)
Fri Aug 03, 2012 10:39 am
Profile
Trooper
Trooper
I tried this but my loop froze
Fri Aug 03, 2012 10:56 am
Profile
Moderator
Moderator
The event script is running on the same thread as the GUI. So when you call time.sleep(), it's actually preventing the screen from being repainted.
What I would recommend is instead using a timer component with a property change event handler on it. Then, every time the timers property changes, it moves the proper component a certain number of pixels using system.gui.moveComponent(). This continues until the component has been gradually moved to the new position.
Hope that made sense...
Fri Aug 03, 2012 3:41 pm
Profile
Who is online
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 1 guest
Search for:
Jump to:
