Well I think the whole idea why this will work is that the group trigger expression executes because the data transfer which is what I need.
If I use a tag change script, Would I still have the proper timing to pull this off?
How about something inside the group item expression like…
if({ShiftReset}=1, executeUpdateQuery(“INSERT INTO motorrun (t_stamp) VALUES (CURRENT_TIMESTAMP)” ),executeUpdateQuery(“INSERT INTO motorrun (t_stamp) VALUES (CURRENT_TIMESTAMP)” ),executeUpdateQuery(“INSERT INTO motorrun (t_stamp) VALUES (CURRENT_TIMESTAMP)” ),executeUpdateQuery(“INSERT INTO motorrun (t_stamp) VALUES (CURRENT_TIMESTAMP)” ),executeUpdateQuery(“INSERT INTO motorrun (t_stamp) VALUES (CURRENT_TIMESTAMP)” ),executeUpdateQuery(“INSERT INTO motorrun (t_stamp) VALUES (CURRENT_TIMESTAMP)” ),executeUpdateQuery(“INSERT INTO motorrun (t_stamp) VALUES (CURRENT_TIMESTAMP)” ),executeUpdateQuery(“INSERT INTO motorrun (t_stamp) VALUES (CURRENT_TIMESTAMP)” ),executeUpdateQuery(“INSERT INTO motorrun (t_stamp) VALUES (CURRENT_TIMESTAMP)” ),executeUpdateQuery(“INSERT INTO motorrun (t_stamp) VALUES (CURRENT_TIMESTAMP)” ),executeUpdateQuery(“INSERT INTO motorrun (t_stamp) VALUES (CURRENT_TIMESTAMP)” ),0)
How would I structure this?
