It is currently Thu May 23, 2013 6:40 pm
Post new topic Reply to topic  [ 14 posts ]
 7.5 on ubuntu 10.10
Author Message
General
General
Post 7.5 on ubuntu 10.10
I cannot seem to find the init.d file in the etc directory. java install seemed to go okay, and so far the
igntion has too. im stuck. any help or info? i must have missed something or the file should be
there.? I wanted to try the new Mint "maya" first but when i installed it, I had really poor performance,
so i couldnt try Igntion.
Tue Jun 26, 2012 5:56 am
Profile WWW
General
General
Post Re: 7.5 on ubuntu 10.10
I'm guessing you're at the part in the guide where you're trying to symlink Ignition into init.d? All services have a script file stored in the directory init.d.
If you're newer to linux, I'd suggest reinstalling linux to a base install and doing the following:
Quote:
wget http://archive.inductiveautomation.com/ia.public.key
sudo apt-key add ia.public.key
sudo nano /etc/apt/sources.list
then add these lines to the end of the file:
Code:
deb http://archive.inductiveautomation.com/apt ignition non-free
deb http://archive.inductiveautomation.com/apt ignition-beta non-free
finally, do the actual install
Code:
sudo apt-get update
sudo apt-get install ignition
Tue Jun 26, 2012 6:20 am
Profile
Moderator
Moderator
There's a graphical installer for linux now too... pretty handy.
_________________
Kevin Herron
Software Developer
Inductive Automation
Tue Jun 26, 2012 7:22 am
Profile WWW
General
General
which one is it? I havent used linux i a while but I am dusting it back off because of ignition.
I will atill work on the steps in the above post because I need practice.
I am also motivated because we use some of this hardware at work:
http://www.advantech.com/embcore/linux.aspx
thanks for the reply's
Tue Jun 26, 2012 7:25 am
Profile WWW
Moderator
Moderator
It's the .run files on the downloads page, "Ignition - Linux Installer 32-bit" and "Ignition - Linux Installer 64-bit"
_________________
Kevin Herron
Software Developer
Tue Jun 26, 2012 7:32 am
Profile WWW
General
General
cool i had downloaded that one too
Tue Jun 26, 2012 7:54 am
Profile WWW
General
General
I got it running this evening! I have a few more questions . will post tomorrow.
Tue Jun 26, 2012 8:15 pm
Profile WWW
General
General
I ended up using linux mint 9 lxde. works great for quick boot and lightweight. the .run
installer worked great also.
Thu Jun 28, 2012 9:07 am
Profile WWW
General
General
Any reason you're using such an old version of Linux? I doubt you will get any support for Mint 9. If you are constrained by limited hardware, why not try an up-to-date version of a lighter distro like Lubuntu 12.04? This also uses the lighter LXDE desktop.
_________________
Al
DataCapture Ltd.
www.datacap.co.uk
Mon Jul 02, 2012 1:44 am
Profile
General
General
Mint 9 also had the jre from sun already installed. I can sure try the lubuntu, my constraint is hardware though that
is for sure.
Mon Jul 02, 2012 3:28 am
Profile WWW
General
General
Lubuntu is very light and is actively supported.
Regarding the JRE, I don't know what the 'correct' version to use is now :( The old version 6 'Sun' version is no longer being developed; the 'official' version 7 is the OpenJDK one (but I don't know if this works 100% with Ignition); and there is also an Oracle version 7.
If anyone from Inductive reads this is would be nice to get a definitive answer.
_________________
Al
DataCapture Ltd.
www.datacap.co.uk
Mon Jul 02, 2012 3:41 am
Profile
General
General
It turns out Linux Mint 9 was an LTS (Long Term Support) version, so it is supported until April 2013.
_________________
Al
DataCapture Ltd.
www.datacap.co.uk
Mon Jul 02, 2012 6:12 am
Profile
General
General
Lubuntu 12.04 is an not an LTS (Long Term Support) release, which means it will only be supported for 18 moths.
I am not necessarily as worried that much about the LTS, as I am
reliability/boot time/ resource consumption/ SUN java already being installed.
Mon Jul 02, 2012 9:08 am
Profile WWW
General
General
We use openjdk7 with Ubuntu 12.04 and we have no issues whatsoever.
Mon Jul 02, 2012 10:36 am
Profile WWW
Who is online
Search for:
Jump to:
