Ok, you need to open the ignition.conf file located in c:\program files\inductive automation\ignition\data. Look for the line that reads:
wrapper.java.command=…
Replace the path to your Java path. Typically, it is c:\program files\java\jre6\bin\java.exe but it might be something different for you. Once you change it save and try starting Ignition again.
