It is currently Tue May 21, 2013 9:57 pm
Post new topic Reply to topic  [ 10 posts ]
 Autologin in romote
Author Message
General
General
Post Autologin in romote
Does the Autologin option work for remote access? I have a project with the autologin option activated. It works perfect for local access, but not for remote. :scratch:
Wed Jun 06, 2012 1:00 am
Profile
Moderator
Moderator
Post Re: Autologin in romote
If the project is set to auto-login, it shouldn't matter where you launch the client. When you launch it on a remote machine what happens? Do you have a startup script that is causing an issue?
_________________
Travis Cox
Inductive Automation
Technical Support Rep.
Wed Jun 06, 2012 6:42 am
Profile WWW
General
General
Also keep in mind that if this is a Panel Edition installation, you only have local launching available.
_________________
Jordan
Duct tape is like The Force. It has a light side, a dark side, and it holds the universe together.
Wed Jun 06, 2012 12:07 pm
Profile
General
General
This is not a panel edition, it is a the works license
Thu Jun 07, 2012 1:31 am
Profile
General
General
Okay, then. What sort of messages are you getting? What happens if you try to use a "normal" login?
_________________
Jordan
Thu Jun 07, 2012 1:51 am
Profile
General
General
Hello,
I have one script to write on a tag when start up. The only messege I receive is the login window, the same in auto-login as in normal.
Mon Jun 11, 2012 10:46 pm
Profile
Moderator
Moderator
What is the issue, is the script not writing to the tag on startup when launching from remote? Is that the only problem?
_________________
James Lorenz
QA/Build Engineer
Tue Jun 12, 2012 1:33 pm
Profile
General
General
The problem is autologin doesn't work for remote connections to my project. Always when I try to acces to It remotely I have to login (as if the autologin wasn't active)
Tue Jun 12, 2012 10:49 pm
Profile
Moderator
Moderator
Can you post the script that is being used on startup?
_________________
James Lorenz
QA/Build Engineer
Wed Jun 13, 2012 8:04 am
Profile
General
General
Sorry, I was confused. I don't have any script running on a client or gateway startup
Thu Jun 14, 2012 3:47 am
Profile
Who is online
Search for:
Jump to:
