It is currently Tue Sep 02, 2014 8:49 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Apache Tomcat error
Author Message
General
General
Post Apache Tomcat error
Everytime I try to launch something from the Ignition gateway (designer or project) I get this error:
Code:
type Status report
message /main/web/deployJava.launch(%27http://localhost:8088/main/system/launch/designer/designer.jnlp%27)
description The requested resource (/main/web/deployJava.launch(%27http://localhost:8088/main/system/launch/designer/designer.jnlp%27)) is not available.
How can I solve this?
Thanks!
Tue May 22, 2012 12:40 am
Profile
Moderator
Moderator
Post Re: Apache Tomcat error
Try changing the Launch Link Script Policy setting to Direct and see if that works. That setting is located on the Gateway Settings page under the Web-Launch Settings section.
_________________
Dave Fogle
Technical Support
Inductive Automation
Tue May 22, 2012 8:02 am
Profile
General
General
Post Re: Apache Tomcat error  Topic is solved
Thanks a lot dave.fogle! the problem was solved just setting the Launch Link Script Policy setting to Direct. :thumb_left:
Wed May 23, 2012 12:32 am
Profile
Who is online
Users browsing this forum: Yahoo [Bot] and 2 guests
Search for:
Jump to:
