Property Editor Scrolls Automatically to the top
Hello,
I’m setting a lot of properties of a component, all these properties are at the bottom of the list.
When I set one (with property binding), the scrollbar goes up to the top, so I have to scroll down again to the bottom and find the next property I want to set.
This issue is not a big deal but it’s very annoying.
Regards
Unpin the property editor from designer and drag it to another monitor, if you have dual monitors. Then you can resize it so you can see everything no matter what property your editing.
I will also make a ticket to get this fixed.
Thank you Greg, Travis.
Have a good day!
This should be better in 7.4.3
