Help with Chart Component
| Author |
Message |
0sm0
Lieutenant
Hi Guys,
I have been given a MSQL Database Table that has been populated with 3 columns. Column 1 has a Date, this has been set as a MSQL "Date" datatype. Column 2 has a Time, this has been set as a MSQL "Time" datatype Column 3 has intergers
I have tried to display the Data (Col 1 and col 3 only) in a Chart component but the Date as the X plot errors as an unknown value for X plot.
I tried to cast the "Date" to a datetime in the Data query which stops the error but fails to draw anything. The Dataset date column shows as 01/04/2012 00:00:00
If I remove the binding and manually manipulate the dataset Date to have an actual time eg. 01/04/2012 01:00:00 the chart works.
So getting to the question....
Is there a way to combine columns 1 and 2 to make a proper Datetime for the chart in a query or can I format just the Date (col 1) in a way that the chart likes?
Cheers for any help.
Tim...
| Thu Apr 19, 2012 5:08 pm |
techerdone
Lieutenant
Joined: Thu May 12, 2011 1:00 pm Posts: 65 Location: Northern California
 Re: Help with Chart Component
When you cast the date column are you using the built in function system.db.dateFormat(date_cell,"yyyy-MM-dd HH:mm:ss") ? Or are you casting with your SQL call? I haven't had any problems using dates that have "no actual time" like your '01/04/2012 00:00:00'.
| Mon Apr 23, 2012 10:54 am |
techerdone
Lieutenant
Just saw that you did the casting it in your date query. Can you iterate through the list and do it in a script instead with the function I mentioned above?
| Mon Apr 23, 2012 10:57 am |
Travis.Cox
Moderator
Joined: Sun Apr 02, 2006 2:46 pm Posts: 1975 Location: Sacramento, CA
Can you post the SQL query that you are using?
_________________ Travis Cox
Inductive Automation
Technical Support Rep.
| Mon Apr 23, 2012 3:41 pm |
0sm0
Lieutenant
[Log Date] is a "Date" datatype in MSQL Using this query the Chart errors with" Illegal type for X value" SELECT [Log Date] as t_stamp, [TR#1 Today permeate (kL)] FROM datalogA
This Query has no errors, but fails to display SELECT cast([Log Date] as datetime) as t_stamp, [TR#1 Today permeate (kL)] FROM datalogA
| Mon Apr 23, 2012 3:52 pm |
Travis.Cox
Moderator
I have a feeling it is not returning an actual date object. Click on the dataset view icon (next to the binding icon) on the Data property of the component. Once opened, click on the date column and tell me what the data type? You will see it below the table.
| Mon Apr 23, 2012 3:57 pm |
0sm0
Lieutenant
ahhhhh...
You are correct, its still showing as a Date type??
| Mon Apr 23, 2012 4:00 pm |
Travis.Cox
Moderator
Date is correct. It should be working ok. Let's check a couple of things:
1) What is the value of the Chart Type property on the graph? 2) If you open the chart customizer (through right click) and select the Dataset Properties tab what is the Renderer for your dataset?
| Mon Apr 23, 2012 4:08 pm |
0sm0
Lieutenant
1/ Default. XY Plot 2/ Default. XY Line/Shape renderer
| Mon Apr 23, 2012 4:51 pm |
Travis.Cox
Moderator
Can you export a copy of the window with the error on it so we can see what is going on?
| Tue Apr 24, 2012 6:42 am |
0sm0
Lieutenant
Doc attached with the chart setup.
No errors just a blank chart.
The error I was finding with just using the [Log Date] without casting it as a datetime was that the Dataset column was being shown as a string even though the SQL column is a Date type.
Doc1.doc [122.5 KiB]
Downloaded 24 times
| Tue Apr 24, 2012 6:24 pm |
Travis.Cox
Moderator
It appears you have it setup correctly but for some reason the data is not showing up. Can you post a couple more screenshots from the chart customizer? One of the X-Axes tab with the axis selected and one of the of the Dataset Properties tab with the Data selected.
| Wed Apr 25, 2012 7:30 am |
0sm0
Lieutenant
Screenshots attached
Cheers
Doc2.doc [99.5 KiB]
Downloaded 23 times
| Wed Apr 25, 2012 1:33 pm |
Travis.Cox
Moderator
Ok, I don't know why the data is not showing up. Everything looks like it is configured correctly. Any chance you can call our tech support or export that window in the designer and send it to us (not screenshots but the actual window)?
| Wed Apr 25, 2012 3:38 pm |
0sm0
Lieutenant
Window Export attached
Cheers
| Wed Apr 25, 2012 3:44 pm |
