It is currently Tue May 21, 2013 11:20 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
 Dataset lookup
Author Message
Lieutenant
Lieutenant
Post Dataset lookup
I've got a dynamic property dataset. It has multiple columns and I need to query against this using the Lookup expression. Problem is, the criteria involves values from 2 of the columns, anyway to do this easily?
Fri Oct 21, 2011 4:58 am
Profile
Moderator
Moderator
Post Re: Dataset lookup
You should be able to use other functions like concat (string concatenation) within your lookup expression.
_________________
Nathan Boeger, CISSP-ISSAP, CCNP Voice, VCP
Not Another Industrial Blog - My SCADA software blog
"Design Simplicity Cures Engineered Complexity"
Fri Oct 21, 2011 5:34 am
Profile WWW
General
General
I do not understand how I could you the concat function. here is what my dataset looks like:
I want to return the value in column "Text", but i want to lookup the number 2012 in column "y" and the number 4 in column "m"
Code:
lookup({Root Container.SellDays},2012,"","y","Text")
how do i incorporate column "m" in the above code?
_________________
Jonathan
Tue Mar 20, 2012 3:24 pm
Profile
Moderator
Moderator
Post Re: Dataset lookup  Topic is solved
You can't do that with the lookup function right now. However, you can add an additional column to the dataset (if it is a SQL query) called ym which is a concatentation of the year and month columns. In MySQL you can do the following:
Code:
SELECT CONCAT(year, month)
_________________
Travis Cox
Inductive Automation
Technical Support Rep.
Tue Mar 20, 2012 3:47 pm
Profile WWW
General
General
ok, i can do that. it sounded like it could be done on the ignition side.
Thanks,
_________________
Jonathan
Tue Mar 20, 2012 3:58 pm
Profile
Who is online
Users browsing this forum: danielsoar, Google [Bot] and 0 guests
Search for:
Jump to:
