It is currently Tue May 21, 2013 5:01 am
Page 1 of 1
[ 6 posts ] |
| Author |
Message |
Justin
Trooper
 MSAccess file size
Would like to find out what the maximum recommended file size of a MSAccess db file should be when running an SQL query in a table. I am trying to view data from a db file that is around 2 gig and that is apperently too big for FactoryPMI. I always get an error after timing out. I have a similar setup reading from a db file that is around 750k in which there isn't any trouble.
| Wed Jan 06, 2010 8:29 am |
Carl.Gould
Moderator
Joined: Sun Apr 02, 2006 2:46 pm Posts: 3770 Location: Sacramento, CA
 Re: MSAccess file size
We don't really have a good idea as to a recommendation for a maximum size for an Access database, since we don't fully support the use of MS Access.
We should be able to get you connected, but beyond that, its really out of our hands. It doesn't surprise me that a large access database's performance isn't acceptable, since Access really isn't a capable relational database.
_________________ Carl Gould
Software Development
Inductive Automation
| Wed Jan 06, 2010 10:15 am |
chris_d_sanders
Major
Joined: Tue Sep 23, 2008 5:07 am Posts: 115 Location: Ardmore, Oklahoma
Carl,
I am having trouble even figuring out how to connect to an Access DB. We are running ignition on Ubuntu Server Edition. The DB I want to connect to is located on another server. How do I go about adding the connection?
_________________ Christopher Sanders
Michelin North America 1101 Michelin Rd Ardmore, OK 73401 (580)222-1406
| Tue Jul 19, 2011 8:10 am |
Travis.Cox
Moderator
Joined: Sun Apr 02, 2006 2:46 pm Posts: 1974 Location: Sacramento, CA
You cannot connect to MS Access from a Linux machine. To connect to MS Access on a Windows machine you need to setup a System DSN (ODBC) connection.
_________________ Travis Cox
Technical Support Rep.
| Tue Jul 19, 2011 9:25 am |
nathan
Moderator
I remember seeing a 3rd party access JDBC driver that might work on Linux. It's very much a use at your own risk application.
_________________ Nathan Boeger, CISSP-ISSAP, CCNP Voice, VCP Not Another Industrial Blog - My SCADA software blog "Design Simplicity Cures Engineered Complexity"
| Wed Jul 20, 2011 3:16 am |
Carl.Gould
Moderator
There is now a pure-java type-4 JDBC driver for access: http://www.hxtt.com/access.htmlI've never used it, so let us know how it goes.
| Fri Jul 22, 2011 2:32 pm |
Page 1 of 1
[ 6 posts ] |
Who is online |
Users browsing this forum: No registered users and 0 guests |
