It is currently Mon May 20, 2013 5:03 pm
Post new topic Reply to topic  [ 6 posts ]
 Connect Win911 to Ignition
Author Message
Trooper
Trooper
Post Connect Win911 to Ignition
Can I connect Win911 to Ignition using the OpcCom Module?
Is there any other way to connect Win911 to Ignition so that an Ack get through to Ignition?
_________________
Erik Burns, PE
Tue May 10, 2011 10:06 am
Profile WWW
General
General
Post Re: Connect Win911 to Ignition
Erik,
I have used SCADAPhone (very similar to Win911) on a couple of jobs with Ignition. What I normally do for the Ack back to Ignition is set up a dummy register in the PLC, and have SCADAPhone/Ignition look at that register for the "Global Acknowledge." Not the most ideal setup, but it does work.
Thanks.
Joe
Tue May 10, 2011 10:29 am
Profile
General
General
you can use a odbc to opc server. kepware makes one.
http://www.kepware.com/Spec_Sheets/ODBC ... Driver.asp
Tue May 10, 2011 4:15 pm
Profile
Cadet
Cadet
You can't directly connect to Win911 using the OPC-COM module. I had to use KepWare, then connect Win911 to Kepware and Ignition to Kepware using the OPC-COM module, you can use OPC-UA to connect to Kepware, but its a few more steps because you have to set up certificates. Also note that the there is a bug with OPC-UA connection dropping out and not reconnecting. I don't know if this has been resolved yet.
Richard
Tue May 24, 2011 9:51 pm
Profile
Cadet
Cadet
Set Win911 alarm to acknowledge on return to normal, then you are going to have to write some script that sets a tag when in alarm condition and resets it when an acknowledge button is pressed in Ignition.
Wed Jun 22, 2011 10:06 pm
Profile
Trooper
Trooper
TopView SQL from Exele can do what you need by using the SQL tables in Ignition.
http://www.exele.com/Products/TopView/topview_about.htm
We have added some details of integrating TopView SQL to Ignition.
http://www.exele.com/Products/TopView/s ... /index.htm
Fri Feb 24, 2012 6:04 pm
Profile
Who is online
Search for:
Jump to:
