in the change log forum thread FactoryPMI version 3.3.2 has the update to override values in editable table cells.
[quote]April 22, 2009 - FactoryPMI 3.3.2 released.
Changelog Entry
Version 3.3.2 build 2754 (Release Date 4/22/2009)
New: fpmi.tag.writeToTagSynchronous() call allows synchronous tag updates.
Improved: Table.setColumnAttributesDataset now uses automatic type-coersion.
[size=150]Improved: Table editing now overwrites/selects all when editing begins.[/size]
Improved: Accessability improved on the dynamic property customizer.
Improved: Various improvements to the IP Cam Viewer component to support Linksys and Mobotix cameras.
Improved: Low level comm detail should improve HTTP keep-alive performance.
Improved: Mouse scroll wheel support added to script editors.
Improved: Easy chart axes now have a minimum auto-range size of 1.0 to prevent strange tick units on flatline data.
Fixed: Bug that caused projects to be unable to launch in Applet mode.
Fixed: Bug that caused an error on classic charts in category mode that had zero rows of data.
Fixed: Bug that caused tabbing off the last cell of an editable table and then clicking a button caused the cell to not commit the edit.
Fixed: Bug in table.setValue() that caused it to not coerce from python datatypes well.
Fixed: Bug that caused the Designer’s custom palettels to not be re-created if they were lost.
Fixed: Chart now draws selection highlight correctly when the chart has a border.
Fixed: Easy Chart now correctly fires mouse events.
Fixed: Bug that caused the module editor’s buffer to get cleared when also running the script playground.
Fixed: Datasource can now support -1 for the Max Idle pooling parameter.
Fixed: Minor bug in the HTML formatting of the Table’s exportHTML function.
Fixed: Possible NPE when deleting a component.
Fixed: Bug that caused the internal authentication profile to not perform soft failover correctly.[/quote]
