Changing alert configuration settings from FPMI interface
| Author |
Message |
apurdom
Private
Joined: Tue Dec 11, 2007 9:39 am Posts: 30 Location: WA
I need to give end users ability to edit the FSQL OPC Item Alert Configuration settings, mainly analog trigger point and ack mode, from an FPMI client interface window. Is there any way to do this?
| Tue Jan 08, 2008 11:39 am |
Carl.Gould
Moderator
Joined: Sun Apr 02, 2006 2:46 pm Posts: 3737 Location: Sacramento, CA
Yes - in the "Low Trigger" and "High Trigger" edit boxes for your analog alarm states, you can hit "CTRL-Space" and choose other items for those alarm trigger points, effectively making the configuration dynamic. You'd just then have to do the plumbing to give your users control over those other points.
If you were using SQLTags, you'd have this nice goodie already made for you that is expressly for the purpose of letting users edit tags' analog alarm states.
Hope this helps,
_________________ Carl Gould
Software Development
Inductive Automation
| Tue Jan 08, 2008 12:21 pm |
jasonpdavid
Corporal
Joined: Wed Oct 20, 2010 3:24 am Posts: 41 Location: Lafayette, LA
 Re: Changing alert configuration settings from FPMI interface
Is there a way to do this in Ignition? I want to allow the operators to add/modify alerts from the live project.
| Wed Nov 03, 2010 8:28 pm |
Travis.Cox
Moderator
Joined: Sun Apr 02, 2006 2:46 pm Posts: 1974 Location: Sacramento, CA
Yes, you can have dynamic low and high setpoints in Ignition as well where you can bind them to other SQLTags.
_________________ Travis Cox
Technical Support Rep.
| Thu Nov 04, 2010 7:57 am |
Robert
General
Joined: Tue Feb 24, 2009 1:30 pm Posts: 874 Location: Calgary
 Re:
This nice goodie also works in Ignition
| Thu Nov 04, 2010 8:12 am |
jasonpdavid
Corporal
"this nice goodie" link is broken.
| Thu Nov 04, 2010 1:46 pm |
jasonpdavid
Corporal
How do I upload a .fwin file into igntion?
| Thu Nov 04, 2010 1:54 pm |
Robert
General
This nice link should take you the extras download page. http://www.inductiveautomation.com/downloads/extras From there select the SQLTags Alarm Edit download under Legacy Products. To get it into ignition, I created a project in FPMI, added the screens, saved and then imported the project into Ignition. During the import I selected only the project/screens I wanted. I could then move the (now) Ignition screens into my Ignition project. I'd post them but I have heavily modified them for my customer. (Including translating them to French  )
| Thu Nov 04, 2010 3:16 pm |
