It is currently Fri May 24, 2013 4:57 pm
Post new topic Reply to topic  [ 3 posts ]
 Update Non Default Data Source
Author Message
Colonel
Colonel
Post Update Non Default Data Source
Hi
I am having some problems with an update script that is updating a database table that is not in the Default data source. The script is been run from an action performed of a button. I get an error while executing saying that there is a spelling error with the data source.
This is what I have tried but it is not working
fpmi.db.runUpdateQuery("UPDATE TBWorkOrder SET MachineID = 1 Where WorkOrderNumber = '1234567' "),[TransOPT]
Am I using the correct syntax for an update to the non default data source?
Thanks
Aidan
Wed Aug 04, 2010 6:34 am
Profile
Moderator
Moderator
Post Re: Update Non Default Data Source
The code should be:
Code:
fpmi.db.runUpdateQuery("UPDATE TBWorkOrder SET MachineID = 1 Where WorkOrderNumber = '1234567'", "TransOPT")
_________________
Travis Cox
Inductive Automation
Technical Support Rep.
Wed Aug 04, 2010 7:32 am
Profile WWW
Colonel
Colonel
Hi Travis
That worked OK for me
Aidan
Mon Aug 09, 2010 3:17 am
Profile
Who is online
Search for:
Jump to:
