It is currently Sat May 18, 2013 8:09 am
Post new topic Reply to topic  [ 64 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Thin Client for Java
Author Message
General
General
Post Thin Client for Java
I am new to Ignition. I am blown away by this product.
I work for a company that has a large installed base of another HMI package. The costs are out of sight with it.
Since Ignition is server based, what are my options for thin client? What does it take to run the necessary Java in a thin client environment?
Can you suggest any prepackaged thin client hardware that might be runing Linux with necessary Java and browser. Naturally I am looking for fanless, flash or SSD based solution.
At some point we might consider booting from a server, but not initially.
Thanks for any help.
Dennis Womack
Tue Mar 02, 2010 11:14 am
Profile
Moderator
Moderator
Post Re: Thin Client for Java
Good question - we are actually working on creating a custom Linux distro optimized to do the minimum amount of work necessary to run an Ignition client, which is:
1) Run a basic windowing system
2) Run Java SE 5 or 6
Not quite sure when it'll be ready however... of course if you're familiar with linux there is nothing stopping you from seting up linux on an industrial touch-pc yourself.
On the Windows side, the lowest we can go is XP Embedded (no CE) because we need to run JavaSE, not JavaME.
I know that some of our integrators have had success with Wyse terminals runnning XP embedded.
Hope this helps,
_________________
Carl Gould
Software Development
Inductive Automation
Tue Mar 02, 2010 12:12 pm
Profile WWW
General
General
I am looking for something like the JackPC or similar from www.chippc.com.
I have inquired of them as to the availability of java SE 5 or 6 running on their platform.
Take a look at their stuff.
My application for Ignition is initially a dashboard showing critical production data.
Thanks
Tue Mar 02, 2010 12:49 pm
Profile
Moderator
Moderator
The JackPC looks pretty cool, but a bit anemic. 128MB ram is going to be rough running the Ignition client. Their EX-PC looks a lot better, but of course it is larger and presumably more expensive.
_________________
Carl Gould
Tue Mar 02, 2010 2:12 pm
Profile WWW
General
General
How much RAM would you reckon would be necessary for web client in linux?
Reckon is southern thing.
Dennis
Tue Mar 02, 2010 2:31 pm
Profile
Moderator
Moderator
Well of course it is going to depend on the complexity of the project, but lets assume the most basic of projects for a dashboard.
Honestly I'm not sure without some experimentation, because I don't have an intuitive sense as to how lean a stripped down Linux installation will run. I would like to see 512mb, but it wouldn't surprise me if you could get away with less.
Sorry for the equivocation, this ultra-low end is somewhat new territory.
_________________
Carl Gould
Tue Mar 02, 2010 4:07 pm
Profile WWW
Corporal
Corporal
I am currently testing an Atom unit from Habey. Passively cooled with heat pipes that are embedded in a fined die cast case. It also has the NVidia ION chipset. I also used a OCZ Vertex 30GB solid state drive (smallest I could find, but only $80 after all the rebates). I used a 2GB memory module. The whole package was around $490 with shipping.
Currently testing with Ubuntu 9.10. By using UNetbootin it installed in around 8 minutes (of course all the service packs took longer to download and install). It will boot up and be ready to run in about 15 seconds (5 of that is waiting on the BIOS).
So far it seems to run very well for a client. You will notice it is a little slower than a desktop at unpacking the jar files, but once the interface is up it seems to do well.
Some links:
The Habey PC from newegg:
http://www.newegg.com/Product/Product.a ... -_-Product
The OCZ SSD from newegg:
http://www.newegg.com/Product/Product.a ... 6820227393
The RAM from newegg:
http://www.newegg.com/Product/Product.a ... 6820231163
Check out the other stuff from Habey (some looks very interesting, they have a passively cooled Core 2 Duo):
http://www.habeyusa.com/products.php?id=112
The next items to try are KUbuntu. I have read it is supposed to be a little more optimized than Ubuntu. I also want to try SUSE, since they have a configuration website where you can build your own image with any additional packages you may need (like the java runtime). Anyway, I am still new to Linux so I am sure there are more people around that can comment on which one makes the fastest client for use with Ignition.
Darren
Fri Mar 05, 2010 4:42 am
Profile
Moderator
Moderator
That looks like a great little box for running the Client - or heck, even the Gateway for a Panel Edition installation.
_________________
Carl Gould
Fri Mar 05, 2010 8:24 am
Profile WWW
General
General
Darren,
Thanks for sharing your experiences. It helps.
Dennis
Fri Mar 05, 2010 12:46 pm
Profile
Corporal
Corporal
Do not know if anyone is following this, but so far my experience with Kubuntu is less than impressive. I have had some issues getting things to work that I got working fairly easily in Ubuntu (things like VNC, XRDP, SSH and Java). The command line APT-GET did not seem to work very well. The graphical installer seemed to work OK. KUbuntu is nicer looking, but seems to use the same amount of resources, so I am going to switch my client back to Ubuntu.
Does anyone have any Linux recommendations for a Ignition client that may be better than Ubuntu? The main items I am looking for is small, fast and easy remote administration. So far, it looks like Ubuntu has been the easiest to work with. May eventually try Damn Small Linux, but for right now I am burned out on installing different versions of Linux.
Darren
Fri Mar 12, 2010 12:09 pm
Profile
General
General
Ubuntu server edition?
If you want off the shelf I think that's about a small as you get. Koppnix map be a good solution as well. Never tried it.
Other then that I think your looking at a build your own.
(Ducks from all the other Linux users touting their fav's)
Fri Mar 12, 2010 12:33 pm
Profile WWW
Captain
Captain
We just finished an install with Ignition running on Windows 7 on a Dell desktop, and four Wyse thin clients with Hope Industrial touch screens as the clients. All you have to do to the thin clients is load Java (takes about 5 minutes total for each client), and that is it. The clients come with 1GB of flash RAM and they run great.
Mon Aug 09, 2010 2:10 pm
Profile
General
General
To: scott_stc
Do you have a model number or part number for the Wyse thin client you used?
What OS is the thin client running?
Thanks for the report, it really helps.
Dennis
Wed Aug 11, 2010 4:12 am
Profile
Captain
Captain
We use the Wyse C90LEW thin client, with the Hope Industrial HIS-ML17-STAE, 17" touch screen monitor. All we had to do was load java and the touch screen driver onto the thin client (no big deal). We set the screen resolution of the project in Ignition to 1024x863. This is a real easy setup and works great.
Wed Aug 11, 2010 11:31 am
Profile
General
General
To: scott_stc
The LEW is Embedded Windows based, have you tried one of the Linux versions? Did the unit come with Embedded Windows and a license for it?
Have you tried to use one of the Wyse Linux based thin clients?
Thanks, I am gathering knowledge.
Dennis
Thu Aug 12, 2010 6:19 am
Profile
Who is online
Users browsing this forum: Google [Bot] and 4 guests
Search for:
Jump to:
