system.tag.browseTags
You do need to specify the provider. If you don’t, we try to use the provider named “default”, not the default of your project. It is going to be slow since it will make several calls to the Ignition Gateway. Each call takes around 100 ms or maybe a little more. I will add a request in to add a recursive flag to the function so you only have to do one call.
