It is currently Thu May 23, 2013 11:41 pm
Post new topic Reply to topic  [ 1 post ]
 [KSB] [March 29, 2012] CSV Driver 1.3.4 b30
Author Message
General
General
Post [KSB] [March 29, 2012] CSV Driver 1.3.4 b30
Hi All,
Here is a driver that watches a file, and parses the line, separated by a comma, and does any of the following:
Pushes data to OPC
Pushes data to a wide table
Pushes data to SQLTags historian
It supports a single line mode, and an append mode.
When you first set up the driver, you must enter your desired properties, and hit save. After that, you will notice the driver is terminated. You need to map each column with a name, datatype, and if pushing to the db, whether it is a primary key, indexed, or neither.
Pricing for this driver is $400.
If you need help, let me know.
File comment: v 1.3.4 b30
TailDriver-module-signed.modl [975.35 KiB]
Downloaded 73 times
Thu Mar 29, 2012 3:48 am
Profile WWW
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
