Ubuntu 12.10 Oracle Java fails to start Ignition
I am currently unable to get Ignition to work with Oracle’s Java on Ubuntu 12.10.
It was installed using:
sudo add-apt-repository ppa:webupd8team/java
sudo apt-get update
sudo apt-get install oracle-java7-installer
I eventually managed to get javaws to produce some output by running /usr/lib/jvm/java-7-oracle/bin/ControlPanel and turning on logging and tracing (logs to ~/.java/deployment/logs/).
I am now getting the following trace:
java.lang.StringIndexOutOfBoundsException: String index out of range: -8 at java.lang.String.substring(String.java:1911) at com.sun.deploy.util.Property.<init>(Unknown Source) at com.sun.deploy.util.Property.createProperty(Unknown Source) at com.sun.deploy.util.JVMParameters$ArgumentSet.addArgument(Unknown Source) at com.sun.deploy.util.JVMParameters.addArgumentImpl(Unknown Source) at com.sun.deploy.util.JVMParameters.parseImpl(Unknown Source) at com.sun.deploy.util.JVMParameters.parseTrustedOptions(Unknown Source) at com.sun.javaws.Main.initializeExecutionEnvironment(Unknown Source) at com.sun.javaws.Main.continueInSecureThread(Unknown Source) at com.sun.javaws.Main.access$000(Unknown Source) at com.sun.javaws.Main$1.run(Unknown Source) at java.lang.Thread.run(Thread.java:722)
I suspect that isn’t very helpful, but if anyone else has any pointers or can confirm that this does work on Ubuntu 12.10 somewhere that would be useful. OpenJDK 7 does work.
Thanks.
It’s a known regression with Oracle’s Java 7u9 on *nix systems. Nothing we can really do about it.
A temporary workaround is to edit the JNLP file and remove all the ‘java-vm-args="-XX:MaxPermSize=128m"’ parameters.
oracle.com/technetwork/java/ … 63279.html
I continue to be impressed by Inductive’s technical support.
I was able to get this working by downloading the jar file referenced in the JNLP (/main/system/launchbin/launchclient.jar) and then running it manually using:
java -cp ~/launchclient.jar
    -Djavaws.sr.gateway.addr.0=dms.datacap.co.uk:8088:8043/main
    -Djavaws.sr.launchts=1354613464838
    -Djavaws.sr.scope=D
    -Djavaws.sr.main=com.inductiveautomation.ignition.designer.DesignerStartupHook
    -Dsun.java2d.d3d=false
    -Djavaws.sr.memory.init=64M
    -Djavaws.sr.memory.max=512M
    com.inductiveautomation.ignition.client.launch.BootstrapSwing
Thanks.
