It is currently Wed Jun 19, 2013 7:25 pm
Page 1 of 1
[ 3 posts ] |
[System]Client/System/CurrentDateTime and dateformat
| Author |
Message |
cgele
Corporal
Joined: Wed Aug 18, 2010 7:29 am Posts: 40 Location: Little Rock, AR
Has anyone seen this issue before? I have a Gateway in PDT time zone and client/designer in CDT. The top date time value is a label component that is formatted using the dateformat function on the system tag "[System]Client/System/CurrentDateTime". The bottom value is a label component that is tied to an expression which is the tag value "[System]Client/System/CurrentDateTime". I've also tried binding the label directly to the tag. With no formatting, the value displays the correct value in the correct time zone. If the dateformat function is applied, then the value displays the correct format using the Gateway time zone only. I need to reformat this tag in the Client time zone.
Thanks
| Tue Jul 03, 2012 12:57 pm |
James.Lorenz
Moderator
 Re: [System]Client/System/CurrentDateTime and dateformat
In your designer, go to Project -> Properties and under Client -> General change the timezone behavior to "Client Timezone". See if that fixes your issue.
_________________ James Lorenz QA/Build Engineer Inductive Automation
| Tue Jul 03, 2012 3:28 pm |
cgele
Corporal
That took care of it.
Thanks, James.
| Thu Jul 05, 2012 5:36 am |
Page 1 of 1
[ 3 posts ] |
Who is online |
Users browsing this forum: No registered users and 2 guests |
