It is currently Wed May 22, 2013 1:24 pm
View unanswered posts | View active topics | View unsolved topics
Page 1 of 1
[ 2 posts ] |
| Author |
Message |
phoulihan
Cadet
 Context is faulted!
I cannot start the Gateway, need help resolving this issue. The Wrapper shows this......then a bunch of failure to connect ro OPC tags.
WARN [ModuleManager ] [12:29:00,221]: Could not read license from HASP key. INFO | jvm 1 | 2012/07/02 12:29:00 | INFO [SystemInfo ] [12:29:00,299]: os.name="windows server 2008 r2", os.arch="x86". INFO | jvm 1 | 2012/07/02 12:29:00 | INFO [SystemInfo ] [12:29:00,299]: Validating native library "ignition32"... INFO | jvm 1 | 2012/07/02 12:29:00 | INFO [SystemInfo ] [12:29:00,314]: Validated ignition32 (ignition32.dll) INFO | jvm 1 | 2012/07/02 12:29:00 | INFO [SystemInfo ] [12:29:00,314]: Loading native library "ignition32"... INFO | jvm 1 | 2012/07/02 12:29:02 | INFO [LocalDBManagerImpl ] [12:29:02,841]: Starting up... INFO | jvm 1 | 2012/07/02 12:29:02 | INFO [LocalDBManagerImpl ] [12:29:02,841]: Looking for existing internal database "settings"... INFO | jvm 1 | 2012/07/02 12:29:03 | INFO [ENGINE ] [12:29:03,356]: open start INFO | jvm 1 | 2012/07/02 12:29:03 | INFO [ENGINE ] [12:29:03,372]: open end INFO | jvm 1 | 2012/07/02 12:29:03 | INFO [LocalDBManagerImpl ] [12:29:03,855]: ... found existing. INFO | jvm 1 | 2012/07/02 12:29:04 | INFO [ENGINE ] [12:29:04,089]: Checkpoint start INFO | jvm 1 | 2012/07/02 12:29:04 | INFO [ENGINE ] [12:29:04,167]: dataFileCache commit start INFO | jvm 1 | 2012/07/02 12:29:04 | INFO [ENGINE ] [12:29:04,167]: Checkpoint end INFO | jvm 1 | 2012/07/02 12:29:04 | INFO [LocalDBManagerImpl ] [12:29:04,167]: internal database "settings" started up successfully.
.....ERROR [Provider[default] ] [12:29:08,301]: [A**/Logic_Tags/****/Reject-4_HR] Error occurred in tag: Error evaluating tag: null INFO | jvm 1 | 2012/07/02 12:29:08 | java.lang.NullPointerException
Please advise.
| Mon Jul 02, 2012 8:45 am |
Colby.Clegg
Moderator
 Re: Context is faulted!
Can you attach the entire wrapper file? The error you pasted there wouldn't cause a fault, there must be something else somewhere.
If you need to get it up and running quickly, feel free to call in. Stuff like this is usually fairly easy to resolve, if you have internet access on the machine. If not, posting the logs is probably easier.
Regards,
_________________ Colby Clegg
Inductive Automation
Software Development
| Mon Jul 02, 2012 8:48 am |
Page 1 of 1
[ 2 posts ] |
Who is online |
Users browsing this forum: No registered users and 2 guests |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
