It is currently Fri May 24, 2013 10:29 am
Post new topic Reply to topic  [ 3 posts ]
 AB Driver Bridged EIP Fails After Timeout
Author Message
Cadet
Cadet
Post AB Driver Bridged EIP Fails After Timeout
I have several remote devices (Micrologix) connected over a cellular network. These devices will occasionally timeout, and until recently Ignition had handled this fine.
Since upgrading to Ignition 7.5 the AB driver has started timing out more often and throwing exceptions, which then knocks out comms to all the other AB devices. The devices still show up as "Connected" by the tags are stale.
Occasionally it will recover, but usually not.
The error is a "BasicExecutionEngine" error, with the message "One-shot task com.inductiveautomation.xopc.driver.api.AbstractNioDriver$DriverIOEventHandler$1@883744 threw uncaught exception" and "java.lang.IllegalArgumentException"
Any help would be appreciated...
File comment: Here's the log export
logs.bin.gz [550.28 KiB]
Downloaded 18 times
Fri Jun 29, 2012 1:31 pm
Profile WWW
Moderator
Moderator
Post Re: AB Driver Bridged EIP Fails After Timeout
Can you post the rest of the stack traces or attach your entire logs.bin(.gz) file?
_________________
Kevin Herron
Software Developer
Inductive Automation
Fri Jun 29, 2012 1:36 pm
Profile WWW
Cadet
Cadet
Definitely...
File comment: logs.bin gzipped
logs.bin.gz [599.95 KiB]
Downloaded 22 times
Fri Jun 29, 2012 1:54 pm
Profile WWW
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 4 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
