Ok, that explains it. If the file originated (Greg B’s) from a version of Ignition that is higher than yours, then it will fail. Projects are not backwards compatible. The only thing I would suggest is to download the latest version from our website and run it in trial mode and open the project that way. Then you can also play with some of our newer features.
