It is currently Mon May 20, 2013 1:12 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 6 posts ]
 Ignition OPC-UA driver for newer AB Compactlogix controller
Author Message
Trooper
Trooper
Post Ignition OPC-UA driver for newer AB Compactlogix controller
The OPC UA driver does not work properly with newer Allen Bradley compactlogix controller (L30/L33 Firmware version 20). The issue has been reported to Tech support. I would like to know the expected date for release of new OPCUA-AB driver to correctly handle the data retrieval from newer AB controllers
Thu Jun 21, 2012 8:28 pm
Profile
Moderator
Moderator
Post Re: Ignition OPC-UA driver for newer AB Compactlogix controller
We'll try to keep you and this thread updated when we know. I believe the developer who will be implementing that has been on vacation this week.
_________________
Kevin Herron
Software Developer
Inductive Automation
Fri Jun 22, 2012 5:36 am
Profile WWW
Moderator
Moderator
We are going through testing and should have it out soon. I'll keep you posted on this thread.
Mon Jun 25, 2012 4:02 pm
Profile
Moderator
Moderator
Both Ignition 7.4 and 7.5 Betas include support for 1769-LxxER processors.
Tue Jul 03, 2012 7:05 am
Profile
Trooper
Trooper
Is the latest version of Ignition (7.5.3) available on your website compatible with newer AB controllers or do I still need to download the beta version of OPC UA driver?
Wed Oct 31, 2012 8:13 pm
Profile
Moderator
Moderator
Post Re: Ignition OPC-UA driver for newer AB Compactlogix controller  Topic is solved
Yes, 7.5.3 should have the compatibility that is mentioned earlier by Tom in this thread.
_________________
James Lorenz
QA/Build Engineer
Fri Nov 02, 2012 9:55 am
Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
