| Author |
Message |
Joseph Mendonca
General
 Drawing Tool Issues
lines, polygons, squares all disappear when rotated in a container. X Y Coordinates after rotating is off the screen.
| Mon Jun 18, 2012 6:52 pm |
Greg.Simpson
Moderator
Joined: Fri Mar 16, 2012 1:00 pm Posts: 552 Location: Sacramento, CA
 Re: Drawing Tool Issues
Is this similar to what your issue is? viewtopic.php?f=72&t=7090Are the objects actually disappearing or are they just moving their X Y coordinates?
_________________ Greg Simpson Inductive Automation Technical Support Rep
| Tue Jun 19, 2012 6:45 am |
Joseph Mendonca
General
Moving their x y coordinates. Objects disappear off the container. Thought this was fixed in an earlier version but it seems to reappear. refer to post "editing lines"
| Tue Jun 19, 2012 7:15 am |
Greg.Simpson
Moderator
What version of Ignition are you currently using?
| Tue Jun 19, 2012 7:17 am |
Joseph Mendonca
General
7.5.0 (b1079)
| Tue Jun 19, 2012 7:56 am |
Greg.Simpson
Moderator
I tried to recreate this on my computer here without success. I tried with various different shapes. I was able to rotate them without any problems and they never changed their X Y coordinates.
When you start to rotate the object, is the red cross that is centered on the object still centered on that object?
| Tue Jun 19, 2012 8:31 am |
Greg.Simpson
Moderator
I stand corrected, we were able to reproduce this. I will talk with the developers about this.
| Tue Jun 19, 2012 8:43 am |
Carl.Gould
Moderator
Joined: Sun Apr 02, 2006 2:46 pm Posts: 3872 Location: Sacramento, CA
Were you rotating them using the "rotate 90 degrees left/right" buttons? If so, then the issue has been fixed for 7.5.1
_________________ Carl Gould
Software Development
| Tue Jun 19, 2012 2:53 pm |
Joseph Mendonca
General
correct the icons on top that look like L's "rotate selection 90 degrees...."
| Tue Jun 19, 2012 8:05 pm |
Carl.Gould
Moderator
Ok just making sure - issue is fixed.
| Wed Jun 20, 2012 9:46 am |
