Re: Problem with start service Ignition Gateway
hi again, I did what you say, and also when I look at the .conf file located at the path you say it's in the right location :
# Locate the java binary on the system PATH:
wrapper.java.command=C:/Program Files/Java/jre7/bin/java.exe
that is the java I installed
and the problem happens again i start the service again and it doesn't wants to run until i uninstall ignition and reinstall again then the Ignition runs again, and i can work until i again shut down the pc
I think the problem maybe is because i am working with a backup *.gwbk from Ignition 64 bits, restored in my Ignition 32 bits. Is that the problem? What can I do in this situation if that is the problem.
Please help, I will appreciate it.
