| Author |
Message |
SamJaimes
General
 Autologin in romote
Does the Autologin option work for remote access? I have a project with the autologin option activated. It works perfect for local access, but not for remote.
| Wed Jun 06, 2012 1:00 am |
Travis.Cox
Moderator
Joined: Sun Apr 02, 2006 2:46 pm Posts: 1975 Location: Sacramento, CA
 Re: Autologin in romote
If the project is set to auto-login, it shouldn't matter where you launch the client. When you launch it on a remote machine what happens? Do you have a startup script that is causing an issue?
_________________ Travis Cox
Inductive Automation
Technical Support Rep.
| Wed Jun 06, 2012 6:42 am |
JordanCClark
General
Joined: Tue Mar 24, 2009 9:14 am Posts: 661 Location: Hudson, MI
Also keep in mind that if this is a Panel Edition installation, you only have local launching available.
_________________ Jordan
Duct tape is like The Force. It has a light side, a dark side, and it holds the universe together.
| Wed Jun 06, 2012 12:07 pm |
SamJaimes
General
This is not a panel edition, it is a the works license
| Thu Jun 07, 2012 1:31 am |
JordanCClark
General
Okay, then. What sort of messages are you getting? What happens if you try to use a "normal" login?
| Thu Jun 07, 2012 1:51 am |
SamJaimes
General
Hello,
I have one script to write on a tag when start up. The only messege I receive is the login window, the same in auto-login as in normal.
| Mon Jun 11, 2012 10:46 pm |
James.Lorenz
Moderator
What is the issue, is the script not writing to the tag on startup when launching from remote? Is that the only problem?
_________________ James Lorenz QA/Build Engineer Inductive Automation
| Tue Jun 12, 2012 1:33 pm |
SamJaimes
General
The problem is autologin doesn't work for remote connections to my project. Always when I try to acces to It remotely I have to login (as if the autologin wasn't active)
| Tue Jun 12, 2012 10:49 pm |
James.Lorenz
Moderator
Can you post the script that is being used on startup?
| Wed Jun 13, 2012 8:04 am |
SamJaimes
General
Sorry, I was confused. I don't have any script running on a client or gateway startup
| Thu Jun 14, 2012 3:47 am |
