Colby,
Do you know which functions are affected by this deadlock? I was able to import my tags via csv file as internal gateway tags instead of through a sql database driving tag provider. I was then able to copy these tags (~700) in the designer and copy them to my database tag provider. Was I just lucky? Or is it just the csv import into a database driving provider that is causing the deadlock.
The more important issue is that this version was to fix a HP-UX licensing problem on 4 of our remote gateways. The licenses are being invalidated by changes to the /bin inode. Our HP admins have been delaying a tomcat fix that invalidates the licenses through a /bin. We can coordinate “re-licensing” the gateways with their installs, but the concern is that something else may change /bin, invalidate the license, and cause loss of data logging.
Thanks,
Jeremy
