I would first check to to make sure your Java installation isn’t hosed and it’s still actually on the path. To do this just open up a command prompt then on the command line enter:
java -version
If you don’t see something like the following I would try re-installing java.
java version "1.6.0_26
Java(TM) SE Runtime .........
If that doesn’t work then you’ll probably want to give a call into support so we can take a look at your system to see if we can figure out what’s going on.
Take a look at any one of those and if they look like binary rather than valid xml you need to replace the file. In most cases we include a clean version of the file filename.xml_clean that you can copy and paste and rename. Once you do that restart Ignition and it should be ok.
In case it helps anyone, in linux (ubuntu at least), “java --version” doesn’t work. You need “java -version”.
I’m running 7.5.7 and getting a 404 error as well. I can see /usr/local/bin/ignition/tomcat/webapps/ROOT/WEB-INF/web.xml and web.xml_clean, but have these other xml files been deprecated or are they located somewhere else in linux?
We have a version 7.2.3.6630 install that has a corrupted ctx0\WEB-INF\web.xml and no web.xml_clean in that directory. All other files Travis listed in his June 2011 post are accountable. Looking for a link to copy of all the xml and xml_clean files for this version.
the application startup link launches the java/ignition startup splash screens but the “Error Launching” “error 404” comes up and the connection is never established. Never got this far with the corrupt xml…
browser still fails to open gateway at either localhost:8088 or 127.0.0.1:8088
I would like to do a fresh install - can you send me a link to download 7.2.3.6630
You can just copy the license.ipl file to your desktop and then put it back in place after you reinstall. As long as your underlying hardware hasn’t changed it will still work.
If you want remote support for any of this you’ll need to wait and call on Monday to work with a support engineer. Or pay for emergency after hours support if you need it today.
