Unable to add new pens using the easy chart on a linux system using Postgres DB. Added new DB but still the same issue. Pens that were trending still trends ok. New pens does show up in the Easy Chart Customizer but not in the edit pen data tag path. Store Forward ERROR: relation “sqlth_te_“id"seq" does not exist
9:29:08 PM History.SQLTags.DataLoader.mydb_Loader No tag information could be found for any of the specified paths. Check that paths are correct. Paths: [oscili]
9:29:08 PM StoreAndForward.mydb.MemoryStore.MemoryForwardTransaction Error forwarding data: ERROR: relation "sqlth_scinfo"id”_seq” does not exist
org.postgresql.util.PSQLException: ERROR: relation “sqlth_scinfo_“id”_seq” does not exist
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:1608)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1343)
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:194)
at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:451)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:350)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeQuery(AbstractJdbc2Statement.java:254)
at org.apache.commons.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:93)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper$SRPreparedStatement.executeQuery(SRConnectionWrapper.java:803)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper.runScalarPrepQuery(SRConnectionWrapper.java:192)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper.runScalarQuery(SRConnectionWrapper.java:181)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper.fetchGeneratedKey(SRConnectionWrapper.java:236)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper.runPrepInsertGetKey(SRConnectionWrapper.java:210)
at com.inductiveautomation.ignition.gateway.history.sinks.TagHistoryDatasourceSink.getIdOfScanclassName(TagHistoryDatasourceSink.java:352)
at com.inductiveautomation.ignition.gateway.history.sinks.TagHistoryDatasourceSink.updateExecAndGetSCID(TagHistoryDatasourceSink.java:322)
at com.inductiveautomation.ignition.gateway.history.sinks.TagHistoryDatasourceSink.storeDataToDatasource(TagHistoryDatasourceSink.java:228)
at com.inductiveautomation.ignition.gateway.history.sinks.AbstractDatasourceSink.storeToDatasource(AbstractDatasourceSink.java:120)
at com.inductiveautomation.ignition.gateway.history.sinks.AbstractDatasourceSink.storeData(AbstractDatasourceSink.java:97)
at com.inductiveautomation.ignition.gateway.history.sinks.AggregateSink.storeData(AggregateSink.java:142)
at com.inductiveautomation.ignition.gateway.history.forwarders.ForwarderThread.run(ForwarderThread.java:134)
