It is currently Thu May 23, 2013 7:00 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
 Floats not been formatted corrctly
Author Message
General
General
Post Floats not been formatted corrctly
I have a SQLTag with the raw value of 2537, data type Float4.
It has a scaling of: Raw high = 100 Scaled High = 1, clamp mode = none
Format string is ##.# KV
looking at the tags Browser, it shows a value of 25.4
when I display in on a screen using it's value and format string it shows as 25.
eg:numberFomat(path_to_tag.value, path_to_tag.format)
What happened to the decimal point?
Tue Apr 12, 2011 5:21 am
Profile WWW
Moderator
Moderator
Post Re: Floats not been formatted corrctly
What component and what property are you using for display. It could be possible you are binding that expression to an integer property.
_________________
Travis Cox
Inductive Automation
Technical Support Rep.
Tue Apr 12, 2011 6:57 am
Profile WWW
General
General
I'm using a label
Wed Apr 13, 2011 2:46 pm
Profile WWW
Moderator
Moderator
Can you post an example of the problem? For example, you can export a window.
_________________
Travis Cox
Wed Apr 13, 2011 3:37 pm
Profile WWW
General
General
Post Re: Floats not been formatted corrctly  Topic is solved
Don't remember this one. Must have been my problem that I solved.
Tue Jul 31, 2012 10:48 am
Profile WWW
Who is online
Users browsing this forum: Google [Bot] and 1 guest
Search for:
Jump to:
