Hi Everybody,
I have the following problem:
I'm developing the SCADA for some industrial plant. This application uses 4 screens (4*1920x1080). In the begining we design the 4 screens in 4 different windows under the same project but now i want to copy/paste it into one big windows. When i copy the first 2 windows all goes ok, i can save the project, close ignition and open it again with no problems.
When I copy the third, i get the following error (sorry for the wall of text):
com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Unexpected I/O error during deserialization.
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer._deserialize(Unknown Source)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserialize(Unknown Source)
at com.inductiveautomation.ignition.designer.DesignerContextImpl.deserialize(Unknown Source)
at com.inductiveautomation.factorypmi.application.model.WindowCache.getWindowInfo(Unknown Source)
at com.inductiveautomation.factorypmi.application.model.WindowCache.getWindowThumbnail(Unknown Source)
at com.inductiveautomation.factorypmi.designer.model.navtree.WindowNode.<init>(Unknown Source)
at com.inductiveautomation.factorypmi.designer.model.navtree.WindowFolderNode.createChildNode(Unknown Source)
at com.inductiveautomation.ignition.designer.navtree.model.FolderNode.loadChildren(Unknown Source)
at com.inductiveautomation.ignition.designer.navtree.model.AbstractNavTreeNode.checkChildren(Unknown Source)
at com.inductiveautomation.ignition.designer.navtree.model.AbstractNavTreeNode.getChildCount(Unknown Source)
at com.inductiveautomation.ignition.designer.navtree.model.AbstractNavTreeNode.isLeaf(Unknown Source)
at javax.swing.tree.DefaultTreeModel.isLeaf(Unknown Source)
at javax.swing.plaf.basic.BasicTreeUI$NodeDimensionsHandler.getNodeDimensions(Unknown Source)
at javax.swing.tree.AbstractLayoutCache.getNodeDimensions(Unknown Source)
at javax.swing.tree.VariableHeightLayoutCache$TreeStateNode.updatePreferredSize(Unknown Source)
at javax.swing.tree.VariableHeightLayoutCache$TreeStateNode.expand(Unknown Source)
at javax.swing.tree.VariableHeightLayoutCache.rebuild(Unknown Source)
at javax.swing.tree.VariableHeightLayoutCache.treeStructureChanged(Unknown Source)
at javax.swing.plaf.basic.BasicTreeUI$Handler.treeStructureChanged(Unknown Source)
at javax.swing.tree.DefaultTreeModel.fireTreeStructureChanged(Unknown Source)
at javax.swing.tree.DefaultTreeModel.nodeStructureChanged(Unknown Source)
at com.inductiveautomation.ignition.designer.navtree.model.AbstractNavTreeNode.reload(Unknown Source)
at com.inductiveautomation.ignition.designer.navtree.model.MutableNavTreeNode.addChild(Unknown Source)
at com.inductiveautomation.factorypmi.designer.model.ObjectHolder.startup(Unknown Source)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$LoadedModule.startup(Unknown Source)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.startupModule(Unknown Source)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.loadProject(Unknown Source)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$StartupProjectDialogHandler.openProject(Unknown Source)
at com.inductiveautomation.ignition.designer.ProjectDialog$5.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
Caused by: java.util.zip.ZipException: invalid stored block lengths
at java.util.zip.InflaterInputStream.read(Unknown Source)
at java.util.zip.GZIPInputStream.read(Unknown Source)
at sun.nio.cs.StreamDecoder.readBytes(Unknown Source)
at sun.nio.cs.StreamDecoder.implRead(Unknown Source)
at sun.nio.cs.StreamDecoder.read(Unknown Source)
at java.io.InputStreamReader.read(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLEntityScanner.load(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLEntityScanner.skipChar(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
... 39 more
Ignition v7.1.4 (b5476)
Java: Sun Microsystems Inc. 1.6.0_19
I read another message in the forum about this error (deserialization) but i couldn't import the window attached.
Can anybody help me and give me some clue about what happend.
thanks!
