Gateway won't start
STATUS | wrapper | 2010/10/04 18:57:13 | --> Wrapper Started as Service
STATUS | wrapper | 2010/10/04 18:57:13 | Java Service Wrapper Standard Edition 32-bit 3.3.9
STATUS | wrapper | 2010/10/04 18:57:13 | Copyright © 1999-2009 Tanuki Software, Ltd. All Rights Reserved.
STATUS | wrapper | 2010/10/04 18:57:13 | wrapper.tanukisoftware.org
STATUS | wrapper | 2010/10/04 18:57:13 | Licensed to Inductive Automation for Ignition Gateway
STATUS | wrapper | 2010/10/04 18:57:13 | Launching a JVM…
INFO | jvm 1 | 2010/10/04 18:57:14 | WrapperManager: Initializing…
INFO | jvm 1 | 2010/10/04 18:57:19 | Oct 4, 2010 6:57:19 PM org.apache.catalina.startup.Embedded start
INFO | jvm 1 | 2010/10/04 18:57:19 | INFO: Starting tomcat server
INFO | jvm 1 | 2010/10/04 18:57:19 | Oct 4, 2010 6:57:19 PM org.apache.catalina.core.StandardEngine start
INFO | jvm 1 | 2010/10/04 18:57:19 | INFO: Starting Servlet Engine: Apache Tomcat/6.0.18
INFO | jvm 1 | 2010/10/04 18:57:19 | Oct 4, 2010 6:57:19 PM org.apache.catalina.startup.DigesterFactory register
INFO | jvm 1 | 2010/10/04 18:57:19 | WARNING: Could not get url for /javax/servlet/jsp/resources/jsp_2_0.xsd
INFO | jvm 1 | 2010/10/04 18:57:19 | WARNING: Could not get url for /javax/servlet/jsp/resources/jsp_2_1.xsd
INFO | jvm 1 | 2010/10/04 18:57:19 | WARNING: Could not get url for /javax/servlet/jsp/resources/web-jsptaglibrary_1_1.dtd
INFO | jvm 1 | 2010/10/04 18:57:19 | WARNING: Could not get url for /javax/servlet/jsp/resources/web-jsptaglibrary_1_2.dtd
INFO | jvm 1 | 2010/10/04 18:57:19 | WARNING: Could not get url for /javax/servlet/jsp/resources/web-jsptaglibrary_2_0.xsd
INFO | jvm 1 | 2010/10/04 18:57:19 | WARNING: Could not get url for /javax/servlet/jsp/resources/web-jsptaglibrary_2_1.xsd
INFO | jvm 1 | 2010/10/04 18:57:19 | INFO [SRClassLoader ] [18:57:19,773]: SRClassLoader init
INFO | jvm 1 | 2010/10/04 18:57:20 | INFO [SRContext ] [18:57:20,334]: Ignition["/main", state=STOPPED] ContextState = STARTING
INFO | jvm 1 | 2010/10/04 18:57:20 | INFO [BundleUtil ] [18:57:20,334]: Requested load of resource bundle ‘common’ for locale ‘en_US’, received bundle for ‘’
INFO | jvm 1 | 2010/10/04 18:57:20 | INFO [SRContext ] [18:57:20,350]: Starting Ignition 7.1.6 (b5739)
INFO | jvm 1 | 2010/10/04 18:57:20 | INFO [SRContext ] [18:57:20,350]: Reloading JDBC classloader.
INFO | jvm 1 | 2010/10/04 18:57:20 | INFO [SecureRandomProvider ] [18:57:20,475]: Creating SecureRandom object…
INFO | jvm 1 | 2010/10/04 18:57:20 | INFO [SecureRandomProvider ] [18:57:20,475]: Generating seed…
INFO | jvm 1 | 2010/10/04 18:57:20 | INFO [SecureRandomProvider ] [18:57:20,475]: … Seed Created.
INFO | jvm 1 | 2010/10/04 18:57:20 | INFO [SecureRandomProvider ] [18:57:20,475]: … SecureRandom Created.
INFO | jvm 1 | 2010/10/04 18:57:20 | INFO [BundleUtil ] [18:57:20,553]: Requested load of resource bundle ‘common’ for locale ‘en_US’, received bundle for ‘’
INFO | jvm 1 | 2010/10/04 18:57:20 | INFO [BundleUtil ] [18:57:20,553]: Requested load of resource bundle ‘gateway’ for locale ‘en_US’, received bundle for ‘’
INFO | jvm 1 | 2010/10/04 18:57:20 | INFO [Application ] [18:57:20,631]: [SRContext] init: Wicket core library initializer
INFO | jvm 1 | 2010/10/04 18:57:20 | INFO [RequestListenerInterface ] [18:57:20,631]: registered listener interface [RequestListenerInterface name=IBehaviorListener, method=public abstract void org.apache.wicket.behavior.IBehaviorListener.onRequest()]
INFO | jvm 1 | 2010/10/04 18:57:20 | INFO [RequestListenerInterface ] [18:57:20,631]: registered listener interface [RequestListenerInterface name=IFormSubmitListener, method=public abstract void org.apache.wicket.markup.html.form.IFormSubmitListener.onFormSubmitted()]
INFO | jvm 1 | 2010/10/04 18:57:20 | INFO [RequestListenerInterface ] [18:57:20,646]: registered listener interface [RequestListenerInterface name=ILinkListener, method=public abstract void org.apache.wicket.markup.html.link.ILinkListener.onLinkClicked()]
INFO | jvm 1 | 2010/10/04 18:57:20 | INFO [RequestListenerInterface ] [18:57:20,646]: registered listener interface [RequestListenerInterface name=IOnChangeListener, method=public abstract void org.apache.wicket.markup.html.form.IOnChangeListener.onSelectionChanged()]
INFO | jvm 1 | 2010/10/04 18:57:20 | INFO [RequestListenerInterface ] [18:57:20,646]: registered listener interface [RequestListenerInterface name=IRedirectListener, method=public abstract void org.apache.wicket.IRedirectListener.onRedirect()]
INFO | jvm 1 | 2010/10/04 18:57:20 | INFO [RequestListenerInterface ] [18:57:20,646]: registered listener interface [RequestListenerInterface name=IResourceListener, method=public abstract void org.apache.wicket.IResourceListener.onResourceRequested()]
INFO | jvm 1 | 2010/10/04 18:57:20 | INFO [RequestListenerInterface ] [18:57:20,646]: registered listener interface [RequestListenerInterface name=IActivePageBehaviorListener, method=public abstract void org.apache.wicket.behavior.IBehaviorListener.onRequest()]
INFO | jvm 1 | 2010/10/04 18:57:20 | INFO [Application ] [18:57:20,646]: [SRContext] init: Wicket extensions initializer
INFO | jvm 1 | 2010/10/04 18:57:20 | INFO [ClusterManagerImpl ] [18:57:20,662]: ClusterState = CONNECTING
INFO | jvm 1 | 2010/10/04 18:57:20 | INFO [WebApplication ] [18:57:20,662]: [SRContext] Started Wicket version 1.4.5 in deployment mode
INFO | jvm 1 | 2010/10/04 18:57:20 | Oct 4, 2010 6:57:20 PM org.apache.coyote.http11.Http11Protocol init
INFO | jvm 1 | 2010/10/04 18:57:20 | SEVERE: Error initializing endpoint
INFO | jvm 1 | 2010/10/04 18:57:20 | java.net.BindException: Address already in use: JVM_Bind:8088
INFO | jvm 1 | 2010/10/04 18:57:20 | at org.apache.tomcat.util.net.JIoEndpoint.init(JIoEndpoint.java:502)
INFO | jvm 1 | 2010/10/04 18:57:20 | at org.apache.coyote.http11.Http11Protocol.init(Http11Protocol.java:176)
INFO | jvm 1 | 2010/10/04 18:57:20 | at org.apache.catalina.connector.Connector.initialize(Connector.java:1058)
INFO | jvm 1 | 2010/10/04 18:57:20 | at org.apache.catalina.startup.Embedded.start(Embedded.java:830)
INFO | jvm 1 | 2010/10/04 18:57:20 | at com.inductiveautomation.catapult.CatapultBase.startTomcat(CatapultBase.java:207)
INFO | jvm 1 | 2010/10/04 18:57:20 | at com.inductiveautomation.catapult.Catapult.main(Catapult.java:82)
INFO | jvm 1 | 2010/10/04 18:57:20 | at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
INFO | jvm 1 | 2010/10/04 18:57:20 | at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 1 | 2010/10/04 18:57:20 | at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 1 | 2010/10/04 18:57:20 | at java.lang.reflect.Method.invoke(Unknown Source)
INFO | jvm 1 | 2010/10/04 18:57:20 | at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:244)
INFO | jvm 1 | 2010/10/04 18:57:20 | at java.lang.Thread.run(Unknown Source)
INFO | jvm 1 | 2010/10/04 18:57:20 | WrapperSimpleApp:
INFO | jvm 1 | 2010/10/04 18:57:20 | WrapperSimpleApp: Encountered an error running main:
INFO | jvm 1 | 2010/10/04 18:57:20 | WrapperSimpleApp: java.lang.RuntimeException: LifecycleException: Protocol handler initialization failed: java.net.BindException: Address already in use: JVM_Bind:8088
INFO | jvm 1 | 2010/10/04 18:57:20 | WrapperSimpleApp: at com.inductiveautomation.catapult.Catapult.main(Catapult.java:84)
INFO | jvm 1 | 2010/10/04 18:57:20 | WrapperSimpleApp: at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
INFO | jvm 1 | 2010/10/04 18:57:20 | WrapperSimpleApp: at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 1 | 2010/10/04 18:57:20 | WrapperSimpleApp: at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 1 | 2010/10/04 18:57:20 | WrapperSimpleApp: at java.lang.reflect.Method.invoke(Unknown Source)
INFO | jvm 1 | 2010/10/04 18:57:20 | WrapperSimpleApp: at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:244)
INFO | jvm 1 | 2010/10/04 18:57:20 | WrapperSimpleApp: at java.lang.Thread.run(Unknown Source)
INFO | jvm 1 | 2010/10/04 18:57:20 | WrapperSimpleApp: Caused by: LifecycleException: Protocol handler initialization failed: java.net.BindException: Address already in use: JVM_Bind:8088
INFO | jvm 1 | 2010/10/04 18:57:20 | WrapperSimpleApp: at org.apache.catalina.connector.Connector.initialize(Connector.java:1060)
INFO | jvm 1 | 2010/10/04 18:57:20 | WrapperSimpleApp: at org.apache.catalina.startup.Embedded.start(Embedded.java:830)
INFO | jvm 1 | 2010/10/04 18:57:20 | WrapperSimpleApp: at com.inductiveautomation.catapult.CatapultBase.startTomcat(CatapultBase.java:207)
INFO | jvm 1 | 2010/10/04 18:57:20 | WrapperSimpleApp: at com.inductiveautomation.catapult.Catapult.main(Catapult.java:82)
INFO | jvm 1 | 2010/10/04 18:57:20 | WrapperSimpleApp: … 6 more
INFO | jvm 1 | 2010/10/04 18:57:20 | INFO [JChannel ] [18:57:20,709]: JGroups version: 2.6.3.GA
INFO | jvm 1 | 2010/10/04 18:57:21 | WARN [SHARED_LOOPBACK ] [18:57:20,927]: failed to join /224.0.0.75:7500 on eth3: java.net.SocketException: Unrecognized Windows Sockets error: 0: no Inet4Address associated with interface
INFO | jvm 1 | 2010/10/04 18:57:21 | WARN [SHARED_LOOPBACK ] [18:57:20,958]: failed to join /224.0.0.75:7500 on net5: java.net.SocketException: Unrecognized Windows Sockets error: 0: no Inet4Address associated with interface
INFO | jvm 1 | 2010/10/04 18:57:21 | WARN [SHARED_LOOPBACK ] [18:57:20,958]: failed to join /224.0.0.75:7500 on net7: java.net.SocketException: Unrecognized Windows Sockets error: 0: no Inet4Address associated with interface
INFO | jvm 1 | 2010/10/04 18:57:21 | INFO [ClusterManagerImpl ] [18:57:21,504]: ClusterState = JOINING
INFO | jvm 1 | 2010/10/04 18:57:23 | Please use CMSClassUnloadingEnabled in place of CMSPermGenSweepingEnabled in the future
STATUS | wrapper | 2010/10/04 18:57:23 | <-- Wrapper Stopped
