Re: High Ignition CPU and Memory Usage
Colby.Clegg wrote:
The group maintenance manager is the entity that runs the "delete records older than X" option you must have selected on the group.
We'll need to look into this- a first glance there does appear to be a problem. I would suggest turning off the "delete records older than..." option on groups until we can get this figured out.
Regards,
Hi Colby
I did have that turned on so I will switch it off. I did delete the table and recreate it as it was suggesting that there was something wrong with the Index for the table. I will switch it off in the other groups that I have it enabled in as well in case it causes problems.
Aidan
