Based on the log messages, the tag is set to an integer and the value being returned is a string. Basically saying that the two data types don’t match. I would look at those tags in the xml file, make sure that the tag is the correct data type. Also if you would like send the xml file your trying to import to support@inductiveautomation.com - ATTN: James , I would be glad to take a look at it.
