Doesn’t matter what version of Ignition (tried various 7.2.11 through 7.5.11 installs) or Java (6uX’s and 7uX’s) but get a segmentation violation. While it still seems to work on the surface, I can’t seem to make an external connection to the OPC Server. Any ideas?
Here’s the install log:
[code]Log started 07/08/2014 at 09:10:07
Preferred installation mode : win32
Trying to init installer in mode win32
Mode win32 successfully initialized
Executing C:\Program Files\Inductive Automation\Ignition/stop-ignition.bat
Script exit code: 0
Script output:
WARN | wrapper | An encoding declaration is missing from the top of configuration file:
WARN | wrapper | C:\PROGRA~1\INDUCT~1\Ignition\wrapper-license.conf
WARN | wrapper | trying the system encoding.
wrapper | Stopping the Ignition Gateway service…
wrapper | Ignition Gateway stopped.
Script stderr:
Preparing to Install
Directory already exists: C:\Program Files\Inductive Automation\Ignition
Unpacking files
Unpacking C:\Program Files\Inductive Automation\Ignition\haspdinst.exe
Creating directory C:\Program Files\Inductive Automation\Ignition\versions
Creating directory C:\Program Files\Inductive Automation\Ignition\lib
Unpacking files
Unpacking C:\Program Files\Inductive Automation\Ignition\ignition.ico
Unpacking C:\Program Files\Inductive Automation\Ignition\lib\catapult.jar
Unpacking C:\Program Files\Inductive Automation\Ignition\lib\servlet-api.jar
Unpacking C:\Program Files\Inductive Automation\Ignition\lib\TimingFramework-1.0.jar
Unpacking C:\Program Files\Inductive Automation\Ignition\lib\wrapper-windows-x86-32.dll
Unpacking C:\Program Files\Inductive Automation\Ignition\lib\wrapper.jar
Unpacking C:\Program Files\Inductive Automation\Ignition\config.xml_clean
Unpacking C:\Program Files\Inductive Automation\Ignition\install-ignition.bat
Unpacking C:\Program Files\Inductive Automation\Ignition\start-ignition.bat
Unpacking C:\Program Files\Inductive Automation\Ignition\stop-ignition.bat
Unpacking C:\Program Files\Inductive Automation\Ignition\uninstall-ignition.bat
Unpacking C:\Program Files\Inductive Automation\Ignition\launch-gcu.bat
Unpacking C:\Program Files\Inductive Automation\Ignition\launch-homepage.bat
Unpacking C:\Program Files\Inductive Automation\Ignition\lib\annotations-api.jar
Unpacking C:\Program Files\Inductive Automation\Ignition\lib\el-api.jar
Unpacking C:\Program Files\Inductive Automation\Ignition\lib\slf4j-api-1.5.3.jar
Unpacking C:\Program Files\Inductive Automation\Ignition\lib\slf4j-log4j12-1.5.3.jar
Unpacking C:\Program Files\Inductive Automation\Ignition\lib\tablelayout.jar
Unpacking C:\Program Files\Inductive Automation\Ignition\lib\tomcat-juli.jar
Unpacking C:\Program Files\Inductive Automation\Ignition\IgnitionGateway.exe
Unpacking C:\Program Files\Inductive Automation\Ignition\hasp_windows_78934.dll
Unpacking C:\Program Files\Inductive Automation\Ignition\versions\context-7.2.11.gpkg
Unpacking C:\Program Files\Inductive Automation\Ignition\lib\catalina.jar
Unpacking C:\Program Files\Inductive Automation\Ignition\lib\jide-common.jar
Unpacking C:\Program Files\Inductive Automation\Ignition\lib\jide-components.jar
Unpacking C:\Program Files\Inductive Automation\Ignition\lib\log4j-1.2.15-min.jar
Unpacking C:\Program Files\Inductive Automation\Ignition\lib\mail.jar
Unpacking C:\Program Files\Inductive Automation\Ignition\lib\tomcat-coyote.jar
Installing Ignition
Executing java -classpath “lib\catapult.jar” com.inductiveautomation.catapult.Upgrader “C:\Program Files\Inductive Automation\Ignition”
Script exit code: 0
Script output:
Script stderr:
Executing C:\Program Files\Inductive Automation\Ignition/start-ignition.bat
Script exit code: 0
Script output:
wrapper | Starting the Ignition Gateway service…
wrapper | Ignition Gateway started.
Script stderr:
Installation completed
Log finished 07/08/2014 at 09:11:42
Executing java -classpath “.;lib/*” com.inductiveautomation.catapult.control.GatewayControlUtil true
Script exit code: segmentation violation
Script output:
Script stderr:
child killed: segmentation violation
Error running java -classpath “.;lib/*” com.inductiveautomation.catapult.control.GatewayControlUtil true : child killed: segmentation violation
[/code]
