It is currently Thu May 23, 2013 8:13 pm
Post new topic Reply to topic  [ 3 posts ]
 Set Multiple Component Property Bindings at once
Author Message
Colonel
Colonel
Post Set Multiple Component Property Bindings at once
I'd like to be able to set multiple components property bindings at the same time.
E.g I have a bunch of lines I want to animate to change colors depending on a condition i.e. pump running etc
Currently I have to set each of the line segments animations separately which is a bit of a pain.
We can set multiple components properties at the same time i,e change all selected components colors to red. But setting all the components properties to the same binding seems to be not allowed.
Appreciate it if you'd consider this.
Cheers
Alex
Mon Jul 16, 2012 10:28 am
Profile
Trooper
Trooper
Post Re: Set Multiple Component Property Bindings at once
Any feedback on this? This definitely needs sorting, we often have a bunch of components that need enable/disable and have to manually copy and paste exactly the same stuff into each component, very annoying.
_________________
Dom
DataCapture Ltd.
www.datacap.co.uk
Wed Oct 24, 2012 11:48 pm
Profile WWW
Moderator
Moderator
Try using Styles, then copying/pasting the dataset between components.
This old video on Styles may help.
_________________
Nathan Boeger, CISSP-ISSAP, CCNP Voice, VCP
Not Another Industrial Blog - My SCADA software blog
"Design Simplicity Cures Engineered Complexity"
Thu Oct 25, 2012 12:15 am
Profile WWW
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 2 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
