| Author |
Message |
Greg.Buehler
General
Joined: Tue May 31, 2011 6:27 am Posts: 310 Location: Minnesota
 A Better Browser™
We've noticed some memory leaks and stability issues when using the ActiveX module for IE support, and it seems like there is no good way to address the issue other than opening an actual instance of the browser.
Can we get a web browser component native to Ignition? I know Webkit isn't the most friendly package in the Java world right now, but anything would be better than embedding IE...
| Mon Jul 16, 2012 6:48 am |
nathan
Moderator
 Re: A Better Browser™
There is certainly both demand and interest for a native web browser in Ignition. As I recall, the issue has been of finding a viable free library or appropriately licensed options. Here is some past discussion of the topic: viewtopic.php?f=71&t=6056&p=16525viewtopic.php?f=71&t=5315After poking through those threads, JXBrowser looks to be worth investigating. You can try it online here.
_________________ Nathan Boeger, CISSP-ISSAP, CCNP Voice, VCP Not Another Industrial Blog - My SCADA software blog "Design Simplicity Cures Engineered Complexity"
| Mon Jul 16, 2012 2:29 pm |
tailfire
General
jbrowse uses the mozilla api and appears to be open source. how would one go about implementing the embedded browser? right now my company has a large already existing internal web. i have used the active x way too much and I believe my project has suffered from it. In many cases I have asked the it guys for access to their db tables where data entry already occurs. The whole process has been a struggle to try to collaborate.
| Tue Jul 17, 2012 5:22 pm |
Kevin.Herron
Moderator
Joined: Mon Oct 27, 2008 4:10 pm Posts: 1333 Location: Folsom, CA
tailfire wrote: jbrowse uses the mozilla api and appears to be open source. how would one go about implementing the embedded browser? right now my company has a large already existing internal web. i have used the active x way too much and I believe my project has suffered from it. In many cases I have asked the it guys for access to their db tables where data entry already occurs. The whole process has been a struggle to try to collaborate. Either we're looking at different JBrowse projects or it doesn't do what you think it does.
_________________ Kevin Herron Software Developer Inductive Automation
| Tue Jul 17, 2012 5:40 pm |
tailfire
General
http://code.google.com/p/jbrowser/have a look at it, it sounds similar to the others... I could be misunderstanding what it does also...
| Tue Jul 17, 2012 5:58 pm |
tailfire
General
I looked up just jbrowse like I typed it, lol not the genome project
| Tue Jul 17, 2012 5:59 pm |
Kevin.Herron
Moderator
tailfire wrote: http://code.google.com/p/jbrowser/
have a look at it, it sounds similar to the others... I could be misunderstanding what it does also... Yeah, different projects. Not sure if we've looked at that one before, but after a quick look I can see that it requires native libraries, which probably ruled it out if we did see it. I'll ask around tomorrow and see.
| Tue Jul 17, 2012 6:02 pm |
nathan
Moderator
Is Apache 2 licensed software good to be distributed with Ignition?
| Wed Jul 18, 2012 12:09 am |
Greg.Buehler
General
nathan wrote: Is Apache 2 licensed software good to be distributed with Ignition? I'm assuming it would be based on your usage of Tomcat...
| Wed Jul 18, 2012 6:04 am |
nathan
Moderator
Ah ha! Good point.
| Wed Jul 18, 2012 6:23 am |
tailfire
General
jbrowser works, is this something that requires module development to add to ignition?
| Sat Jul 21, 2012 9:10 pm |
tailfire
General
http://www.webrenderer.com/?wrnewsSo Is there any hope for this? If one was to purchase this as 3rd party how would it integrate with ignition? Would it be a module that gets installed? The 'better browser' is a worthy investment.
| Thu Jul 26, 2012 5:53 am |
Josh
Trooper
Joined: Tue Jun 14, 2011 3:09 pm Posts: 11 Location: Calgary, AB
tailfire wrote: http://www.webrenderer.com/?wrnews
So Is there any hope for this? If one was to purchase this as 3rd party how would it integrate with ignition? Would it be a module that gets installed? The 'better browser' is a worthy investment. It seems that the best option would be to create a module that you could install into Ignition. I don't think it would be too much work to create a client/designer module that implemented a new browser by creating a new vision component. In the case of WebRender you would need to load the correct library depending on the platform as it appears to have native code dependencies.
| Thu Jul 26, 2012 6:52 am |
tailfire
General
Jul 30, 2012 7:56:51 PM ru.atomation.jbrowser.impl.JBrowserManager initialize INFO: Using xul runner dir: C:\Users\t\workspace\jbrowser_for_ignition\jbrowser\xulrunner\xulrunner Jul 30, 2012 7:56:51 PM ru.atomation.jbrowser.impl.JBrowserManager initialize SEVERE: failed to initialize mozilla org.mozilla.browser.MozillaException: java.lang.UnsatisfiedLinkError: C:\Users\t\workspace\jbrowser_for_ignition\jbrowser\xulrunner\xulrunner\javaxpcomglue.dll: Can't load IA 32-bit .dll on a AMD 64-bit platform at org.mozilla.browser.MozillaExecutor.mozInit(MozillaExecutor.java:675) at ru.atomation.jbrowser.impl.JBrowserManager.initialize(JBrowserManager.java:147) at ru.atomation.jbrowser.impl.JBrowserManager.<init>(JBrowserManager.java:67) at ru.atomation.jbrowser.impl.JBrowserBuilder.buildBrowserManager(JBrowserBuilder.java:127) at ru.atomation.jbrowser.snippets.GettingStartedSnippet.main(GettingStartedSnippet.java:25) Caused by: java.lang.UnsatisfiedLinkError: C:\Users\t\workspace\jbrowser_for_ignition\jbrowser\xulrunner\xulrunner\javaxpcomglue.dll: Can't load IA 32-bit .dll on a AMD 64-bit platform at java.lang.ClassLoader$NativeLibrary.load(Native Method) at java.lang.ClassLoader.loadLibrary0(Unknown Source) at java.lang.ClassLoader.loadLibrary(Unknown Source) at java.lang.Runtime.load0(Unknown Source) at java.lang.System.load(Unknown Source) at org.mozilla.xpcom.internal.JavaXPCOMMethods.registerJavaXPCOMMethods(JavaXPCOMMethods.java:57) at org.mozilla.xpcom.internal.MozillaImpl.initialize(MozillaImpl.java:48) at org.mozilla.xpcom.Mozilla.initialize(Mozilla.java:668) at ru.atomation.jbrowser.impl.JBrowserManager$2.run(JBrowserManager.java:162) at org.mozilla.browser.MozillaExecutor$4.run(MozillaExecutor.java:646)
Well I was taking a stab at implementing jbrowse and here is one fatal reason concerning the dependency topic , that it appears this free option wont work. I sure would like to see this feature but appears I need to move on.. I started trying to build it in eclipse on a 64bit OS. It might run on 32 bit machine....
| Mon Jul 30, 2012 5:03 pm |
tailfire
General
Kevin.Herron wrote: tailfire wrote: http://code.google.com/p/jbrowser/
have a look at it, it sounds similar to the others... I could be misunderstanding what it does also... Yeah, different projects. Not sure if we've looked at that one before, but after a quick look I can see that it requires native libraries, which probably ruled it out if we did see it. I'll ask around tomorrow and see. The native libraries mentioned above..Would this be the xulrunner?
| Mon Jul 30, 2012 5:13 pm |
