It is currently Fri May 24, 2013 3:29 am
View unanswered posts | View active topics | View unsolved topics
Page 1 of 1
[ 6 posts ] |
| Author |
Message |
eaolson
Corporal
 Level Indicator overlays
One of the things I noticed while upgrading from FactoryPMI to Ignition is the change in behavior of the Level Indicators. Namely, if the value is < 0 or > capacity, it displays the "limit exceeded" overlay.
I find it's pretty common to have level transducers that are not perfectly calibrated, so often a tank or whatever will be empty and the level reading is something like -2%. That, to me, seems to be a much less severe case than a communications error.
I think it would be nice to have a check box or whatever that made that particular overlay optional. I realize this can be fixed by just coercing the value with an expression, but that's a bit of a nuisance.
| Fri Jul 06, 2012 11:22 am |
Robert
General
Joined: Tue Feb 24, 2009 1:30 pm Posts: 878 Location: Calgary
 Re: Level Indicator overlays
Two options: 1. every binding has an overlay opt out checkbox. usually near the bottom right of the popup. Check this and no overlay will bother your operators again.
2. When you apply scaling to a tag, you can set the clamp mode to prevent it from exceeding the full value limits.
| Fri Jul 06, 2012 11:38 am |
AlexW
Colonel
hmm. I tried this on a tank component.
Unfortunately even after checking the "overlay opt out" check box on the 'Value' binding. It is still showing up with the overlay in the designer.
Thoughts? I'd prefer not to use the clamp as I'd prefer for operators to still be able to see sensors not operating correctly i.e. failed high. Clamping the value to within range will prevent them from
| Tue Jul 10, 2012 1:57 pm |
JordanCClark
General
Joined: Tue Mar 24, 2009 9:14 am Posts: 661 Location: Hudson, MI
I posted a tank display here That may give you some ideas.
_________________ Jordan
Duct tape is like The Force. It has a light side, a dark side, and it holds the universe together.
| Wed Jul 11, 2012 7:58 am |
AlexW
Colonel
So what is the point of the "overlay opt out" check box?
edit. Found the answer in the manual. Has nothing to do with whether out of range or not
Overlay Opt-Out Choosing this option will ignore the quality of the chosen tag, making it have no effect on the component's quality overlay.
| Wed Jul 11, 2012 5:21 pm |
eaolson
Corporal
Yeah, the Overlay Opt-out doesn't seem to apply to this particular overlay. What I did wind up doing to get around this was to bind the level value to an expression that coerced the tag in question to be > 0 and < capacity, removed the level's numeric display, and added a numeric indicator bound to the uncoerced tag value.
| Mon Jul 16, 2012 11:34 am |
Page 1 of 1
[ 6 posts ] |
Who is online |
Users browsing this forum: No registered users and 1 guest |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
